Question about Kodak EasyShare EX1011 Digital Picture Frame
Hear a click then the panel shuts off
My EX1011 has recently started to shut off the screen after only a few minutes of viewing. At times I can still see a subtle image on the screen but the brightness is totally gone. This screen is just at two years old. Any suggestions on what can be done or is this another device for the e-recycling stack?
    Scholar:
  • 47 Answers
Try these troubleshooting steps:
1. Turn the frame off.
2. Unplug the power cable from the wall outlet.
3. Remove any memory card or flash disk from the frame.
4. Connect the power cable directly to a wall outlet.
5. Turn the frame on.
6. Use a paper clip to press the button inside the pinhole on the back of the frame.
If after trying the above steps and the frame still have the same problem, then we need
to send the frame in for a repair as per warranty guidelines.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
Posted on Jan 04, 2010
The picture frame is all strips and does not show the picture
Posted on Jul 22, 2011
Sunlighter hot tub
Sounds like the pump motor is tripping out on thermal overload. Touch that particular motor just after it shuts off. If it is "very" hot to the touch, it probably needs replacement.
Oct 16, 2013 | Electrical Supplies
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
I have an LG 47LB5D LCD Tv that shuts off after approximately 30 minutes running time. It will cycle back on after a few minutes, so I assumed it was the power control board; replaced it but Tv still shuts...
It sounds as if the resistors on the board of the television are shot not much that can be done but replace all of the boards in the television you should try and aim fans into the vents on the television and see if its stays on for longer
Mar 05, 2011 | LG 47LB5D Television
My Kodak Easyshare 1011 has recently started to turn off
The firmware of your digital picture frame needs to be updated but since you can't do anything because after a few seconds the frame will shut down it needs to be send for repair. To process repair visit www,kodak.com/go/itg. Follow the troubleshooting guide page and at the end of the troubleshooting guide you will be able to fill up a form to send frame for repair.
Jun 06, 2009 | Kodak EasyShare EX1011 Digital Picture...
KP-51HW40 - Auto shut down problem
I had the same problem. i was told by one of these so-called experts @ fixya that my flyback transformer needed to be replaced (the 8 blinks on the standby was the indicator). but i recently replaced it and im having the same problem. sorry. no advice. good luck.
Jun 18, 2008 | Sony KP-51HW40 51" Rear Projection...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Kodak EasyShare EX1011 Digital Picture Frame Logo
306 people viewed this question
Top Kodak Photography Experts
Michael Galve
Michael Galve
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
