Question about Amana NDE2330AY Electric Dryer
Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
My 2 year old Amana electric dryer recently started running for an extended period of time without heating up.
I have removed the face and pulled the heating coils out - they do not look burned but i'm not sure how to tell if the unit is defective.
I do not have a multi meter but will go get one if needed. Could someone let me know how to trouble shoot if the problem resides with the element, fuse or thermostats.
I am capable of changing the parts myself, i simply need to identify which parts to change. Any help would be appreciated.
Thanks!
  • 3 more comments
  • tmonax Nov 14, 2007
    Thanks for the advice. I looked at multimeters today.
    I also ordered a replacement fuse kit, it replaces both fuses and was only 15 bucks. Hopefully it'll do the trick.
    Any advice about how i can test the actual element?
  • Anonymous Dec 31, 2007
    Same problem - I purchased the two fuse units (upper and lower limit) and the unit did nothing . No heat. Everything runs fine and no apparent breaks in the coils. Mine is the same age at less than 2 years old. Amana sure isn't Amana anymore.
  • GLADNISHIA Mar 19, 2008
    AMANA DRYER MODEL NUMBER IS LE4207W RUNS AND BLOW ONLY COLD AIR.
  • barbie1227 Dec 19, 2008
    I have an Amana dryer thats 3 years old runs great but wont heat up ?
  • dougrturner Jan 20, 2009
    my amana dryer not quite two years old runs for hours on autmatic dry, and doesnt heat well. help me out
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Posted on Nov 06, 2008
  • 291 Answers
U need to tap wires on the heater to may sure theres no break... would be lot easier to trouble shot with multi meter.. so u can ohm out parts and check for voltage
Posted on Nov 06, 2007
Amana 7200 dryer, runs but has no while running.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Amana NED7200TW Electric Dryer
Amana model 2330aww....runs but does not heat up....just started happening, dried one load then it stopped heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 15, 2010 | Amana NDE2330AY Electric Dryer
My 4 1/2 year old electric Whirlpool dryer runs
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 26, 2010 | Whirlpool WED5100SQ Front-Load Electric...
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
I have a Amana Electric Dryer NED5500TQ. When I
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Sep 25, 2009 | Amana NED5500TQ Electric Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Dryer heat output is 148, but takes several runs to dry clothes
You most likely have a ventilation problem somewhere in your exhaust line. This can be very dangerous and a fire risk. You need to do a thorough check of your vent pipe and make sure it is clear and the exterior trap door is working freely.
Jan 26, 2009 | Amana ALE643RB Electric Dryer
Fisher&Paykel electric dryer: starts then stops
it sounds like the thermal fuse is bad. if you take the front cover off you will see a fuse with a red button. that might be what is causing it
Aug 02, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Amana NDE2330AY Electric Dryer Logo
1,060 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
