Question about Maytag Atlantis MAV6000 Top Load Washer
Washer is filled with water,,it wont drain,,nor
Washer filled,,but wont agitate,wont spin,wont rinse,nor drain,,dial is makin a buzzing noise
  • 454 Answers
Sounds like a bad lid switch. When you close the top lid, there is a safety switch that closes, it is actuated by a pin attached to the lid, there will be a small hole located on top of the machine, somewhere on the perimter of the top of the tub. Could also be a bad timer.
Posted on Jun 25, 2009
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
My hotpoint washer wont agitate spin or drain. it makes a clunking noise when you try to change the cycles manually
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
SERVICE MANUAL
My page shows more HERE
Sep 24, 2012 | Hotpoint VVSR1070D Top Load Washer
Washer will not agitate/spin.
The lid switch is fine. The timer needs to be replaced.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Will agitate; but won't go into rinse or spin - even if place the
If it will not spin/drain/advance timer or make any noise when you set it to do these options your problem is the lid switch. Your washer thinks the lid is up so it wont run as a saftey measure. You can order and install this item and its pretty easy and very common.
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
381 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
