Question about Pioneer Elite EX500 600Watt A/V Receiver Home Theater with FREE Speakers System
Once your turn off the plasma TV, you cannot turn it back on until it cools down
If you turn off my Sony plasma tv you cannot turn it back on until about 10-15 minutes after it cools off--is that correct?
    President:
  • Pioneer Master
  • 1,114 Answers
No. If it's a Plasma, you can turn it off and on at will. If it's an LCD, that is true, and Sony's won't let you turn them back on. You would see the power led flashing. Once the LCD bulb cools down then it will turn back on. Hope this helps
Posted on Jun 20, 2009
How do I fix a power problem with an Insignia Plasma TV Model NS51P680A12?
Sounds like something heating up - get a freeze can and spray the various boards one by one until the tv comes back on then you will know which one it is - probably the y-sus board or psu board!
Swollen caps on which board - that will more than likely be the problem board and more than the caps will be damaged by the heat in Plasmas - I leave the back off my plasma to stop the heat buildup!
Nov 03, 2015 | Insignia Televison & Video
Tv cuts off, periodically. Does it get hot?
Hi, If your TV turns off. The thermal switch is working. Meaning that your TV is getting hot and needs to shut off to cool down. Make sure vent holes are open in back of set, clean if needed. You can put a fan behind set for cooling.
Plasma's do get alittle warm so don't cover or block vent holes.
If this continues seek out a repairman for further info.
Oct 02, 2013 | Sanyo DP50747 50 in. Plasma TV
Hi i have MAXENT TV 50" plasma im loking for dish network remonte code to program on it please help
We show no codes listed for Maxent televisions. The best method for programming this remote is called a Power Scan, the steps are below:
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
May 08, 2011 | Maxent MX-50X1 50 in. Plasma Television
Sony Plasma TV making a sound that sounds like a fan running when TV is warmed up.
Plasmas can sometimes run hot so there are usually a fan or two in the back of them that turn on and help cool em down.
Oct 06, 2010 | Sony KDE-37XS955 37 in. Plasma HDTV
After about an hour picture gets a blue distortion. YOu have to turn off TV and let cool off. Once it cools off it works until it gets hot again.
replace these electrolytic caps in the power supply,
C233,C234 3300mf/16volt
C241,C238 470mf/35volt
C236 1000mf/25volt
you can also go to shopjimmy.com enter model number scroll down to find power supply if they dont have it in stock write down the part number to find it on the web,it would be cheaper for you to replace the bad caps.
Sep 24, 2009 | Vizio VP322 32 in. Plasma TV
Plasma problems
It's in standby mode.
Let's do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
Let me know how this works
Jan 30, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony tv snow for first 5 minutes on
Probably dry solder joints in the tuner section.
When the set warms up, the faulty joint/s make contact, then lose contact again when it cools down.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My TV turns on and off randomly!
Remove the rear cover & turn set on, pull all the connectors off one at a time and push back on. I have had loose connectors cause this problem, and by doing the above has fixed it. Note do the pull off and push back on of the connectors, with the tv unplugged from the AC outlet.
Jul 14, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
