How do I replace the freon in this a/c unit?
Also, where can I buy the freon?
  • 508 Answers
If r-134a walmart if anything else you haft to have a license
Posted on Jun 25, 2009
Can I buy a new inside unit for a MS24WN outside unit
EPA regulations: Freon 22 units are no longer available, Units that are compatible are available They come pre charged with nitrogen It must be dumped. If there is freon in the old system it should be pumped down into the condenser unit before the inside unit is removed, Close the high side king valve and run the unit until the low pressure reads near O Close the low pressure king valve. and turn unit off. 410A freon units are readily available. Most if not all 2 ton air handlers will work with any outside 2 ton unit though some building codes will not allow a mix. Their reason: if something fails who is to blame:
Dec 02, 2014 | Heating & Cooling
How do you add freon to haier window unit air conditioner
Window units do not come with service ports. You can buy them at local parts houses, but unless you have the freon, not gonna do you any good. Window ac use either r22 our 410a, and that cannot be bout without being certified.
Aug 18, 2012 | Haier Heating & Cooling
My hotpoint refrigerator leaked out all the freon. Can I repair it myself?
this hot point or ge had freon leak at evaporator coils. I replaced that piece and here is video.
Nov 27, 2011 | Hotpoint HSM25GFRSA
Suncutter A/C needs freon. I have added freon to my vehicle system myself. Are home units set up the same way as automobile systems?
To a point yes they are. But home units require a different type of freon, the oils are different and you can cause major damage using the wrong freon or using the same gauges that where used to fill a car, also the residential or commercial units use a very specific amount of freon and if you are to high or to low you can cause damage. You should not be low on freon and it is recommended that you get a qualified service technician out to look at your unit and run dye through it to find the leak. If this is a newer system you are running very high PSI throughout your system and without the proper equipment you can cause damage to yourself or the unit. I hope that this kind of answers your question
May 29, 2011 | Heating & Cooling
Husband blew out the freon "container" of our Whirlpool 4.4 c.f. refrige - what "contains" the freon? I'm trying to prevent him from going out & buying a new fridge if we can just...
Sorry to read about your problem, I hope this helps you out.
No you cant fix it, it takes special equipment to replace the freon...Please call a service company to make the repairs and do not have you husband touch the system. or you may have to buy a new unit. 2nd you need a EPA federal lic, to work with freon....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Refrigerators
Ok i have 40.00 dollars and need freon for my home central ac unit,how would i put it in the unit? can u please help me?ok it blows out warm air instead of cold air and the thermastat is saying 88 degrees...
Depending on where you live, you would need another
200.00 to buy the freon and another 60.00 to buy the
refrigerant gauges.
Turn the unit off outside, turn your thermostat all the way to cool and as low as it will go. Go back outside
and turn the power back on, The condensor fan and the compressor should both be on.
If neither one is on, or one is and one is not then 40.00 might be able to buy you a hard start kit
Jun 30, 2010 | Whirlwind FH-778 Air Conditioner
I have a Duo-Therm 57915 (13500 BTU) that frosts up the bottom 1/4 of the coil and shows signs of a freon leak on the copper tubing (oily substance). I assume I have a freon leak. It a 2006 unit. Is it...
Buy a new one. Your repair will cost approx 2/3rd (or more) the price of your new unit. Your old unit has no warranty left while your new unit will have a warranty. :-)
May 03, 2010 | Dometic Rooftop RV Air Conditioner
Controls checkout... no compressor start. Freon??
You can buy line taps that clamp on to give you service ports
Sep 25, 2009 | Dometic Rooftop RV Air Conditioner
1987 toyota corolla freon
Well, It takes R-12 freon. Sadly, they don't sell it in the US anymore.
You'll have to call around A/C shop to see if can retrofit you A/C unit to use the R-134A.
Apr 21, 2009 | 1987 Toyota Corolla 2 Door
Punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Nov 09, 2008 | Maytag M7Y15F2A Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
