Question about Lexmark X2690 All-In-One InkJet Printer
How do you attach the power cord? - Lexmark X2690 All-In-One InkJet Printer
    Sergeant:
  • 173 Answers
Just check in back side of your printer jsut push the power cod into its jack.
Posted on Jun 25, 2009
  • 31 Answers
To the back of the printer.......
Show me how and where to hook up power cord, to charge battery for camcorder, omni2
many camcorders have a power pack that attaches to the camcorder and then the battery attaches to the power pack you can also put the plug in and run the camcorder when everything's attached
Feb 26, 2015 | Video Cameras
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
It would be the easiest way, attaching a male plug to the end of the severed cord so it can be used with an extension from the power outlet. Safe too if you duplicate the wires in the old portion, as the cleaner may or may not be earthed.
Oct 13, 2014 | Vacuums
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
The power cord was crushed and no power is getting to the tv. Is the plug able to be replaced as this has happened below the splitter???or whatever the thing is on the cord. thanks Shelley
If the power cord comes off the television you can replace it with a standard power cord. You have to tell the Radioshack employee how many volts and hertz. That should be on the back of the television. If the power cord does not come off the television you can find someone perhaps a tv repair guy that can attach another power cord to the one on the television. My dad actually did that when his older television would no longer power on. He took the bottom part of a power cord from a fan that was no longer working and attached it to the television's power cord. It has been working like a charm ever since for years.
Sep 28, 2010 | Televison & Video
I was given the dryer, and the cord unattached. I want to be sure I attach them correctly. The cord has three prongs and ther are three holes for attachment. Where should the grounding be atached?
For a 3-pronged cord, the ground (nuetral) is the middle wire on the cord and is attached to the middle terminal post. the outside wires are attached to the outside posts. It doesn't matter which wire goes to which side.
On 4-pronged cords, there is a fourth green wire that is attached the unit's case for grounding purposes. Which cord you use is dictated by what power outlet you have, 3 or 4-pronged.
If I can help anymore, please let me know.
Best, G
Aug 03, 2010 | Whirlpool Dryers
We were recently given a kenmore dryer, without a power cord. How do I attach the 3 wire power cord that I bought to relace it?
Attach the power cord as follows:
1. Remove the cover on the terminal block on the back of the dryer.
2. Match the corresponding wire colors as follows:
a. RED - HOT (120VAC)
b. BLACK - HOT (120VAC)
c. WHITE - Neutral (0 VAC) - should have a ground strap attached, tying it equipment ground.
3. Make sure you use the power cord strain relief clamp when installing the power cord to prevent chaffing of the insulation and wire strain which can lead to broken wires.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
For clarification purposes, the following link explains dryer power cord configurations/installation in detail:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 17, 2010 | Dryers
The wrong power cord was attached and now it wont do anything i think its burned out
Most likely it's just a power regulating diode on motherboard right next to DC connector, that burned out. Minor repair, but expansive.
Apr 18, 2009 | Gateway MT3705 Notebook
Supersonic FC2200 TV Power Cord Usage
need a power cord for FC2200 supersonic hdtv. where can i find one
Jun 30, 2008 | Supersonic FC2025 9 in. TV/DVD Combo
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Jan 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Open Questions:
See all Lexmark X2690 All-In-One InkJet Printer Questions
Lexmark X2690 All-In-One InkJet Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
