Question about Coleman Sport & Outdoor - Others
1995 Coleman Utah won't stay up after cranking it up
When I crank up my camper it doesn't sound like the gears are working. When it is all the way up the tension is never relieved from the handle and it goes back down unless tied off or boards are put under roof. How can I fix the problem?
5 Suggested Answers
SOURCE: 1995 Coleman Utah pop-up won's stay up
I had the same problem on my 1997 Coleman Fleetwood Bayside. I took out the spring pin from the crank shaft using a finishing nail and a hammer. I then put a 9/16th" socket inside to hold the nut in place while I used a pipe wrench on the outside of the crank shaft to turn it about 1/4-turn clockwise. Voila! Now it works.
Posted on Jun 17, 2009
  • 13 Answers
SOURCE: I have cracks on my coleman pop camper rubber roof
Roll with a fibrous roof coating. make sure it has the fibers or else it will not adhere to the cracks or metal.
Posted on Oct 27, 2010
  • 643 Answers
SOURCE: coleman popup camper top raises
put it all the way up then gently crank a bit more. The dealer made me swear to be careful because that extra cranking while open can break the lines. I recall they said if this trick didn't work I would need to bring it in.
Posted on Nov 11, 2010
hmerchant110
  • 7191 Answers
SOURCE: Where can I obtain an
You can download and print the manual from the manuafacturer's download support website in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
If your model is not listed on the page which opens, you will have to contact the manufacturer's customer support and check whether they can provide the manual. Click here for contact details.
Hope this helps. Thanks for using FixYa.
Posted on Jul 17, 2011
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
My 1999 flagstaff pop up camper wont crank up
The crank up gear is defective, replace the crank assembly.
May 18, 2017 | RVs
Starter works fine but won't crank engine. the pick up has to be given a push first before it starts
If the starter is spinning when you try to start but doesn't spin the engine over then you most likely have teeth missing off the flywheel ring gear. The facts that you say you have to push it and then it starts means the flywheel position changes and the starter has good teeth on the flywheel to engage. To confirm this next time the engine won't crank over remove the starter and look inside at the flywheel for missing flywheel teeth.
Mar 13, 2012 | Ford Cars & Trucks
Coleman bayside 1997 pop up camper, had to remove some motor part related to cranking up. won't stay up unless motor part is put back in. help? female with trouble and wanting to camp this weekend
Sounds like the motor also holds up the top.
can you try to use something loke a broom stick thick piece of wood to hold up the canopy top till you get a chance to get a new motor.
You would prop up the top with a piece of wood right in the same area as the framing.
Tie a piece of string or bungee cord to hold the stick in place,to ensure the top dosent come down on you.
You might need to cut the stick to leanth as well as using more than one piece of wood.
Gool luck,Gary
Sep 21, 2011 | Coleman Water Sport
I need the threded rod assembly that cranks up the hard top on my coleman popup camper 1994 i think
IF YOU HAV THE OLD 1 . CHECK AROUND TO YOUR LOCAL CAMPER , OR MACHINE SHOP OR WELDING SHOP, IT MIGHT BE REPAIRABLE.. IF NOT CHECK THE WEB FOR CAMPER CLUBS OR FORUMS .. JAY
Jul 23, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Rockwood pop-up camper.when i try to use hand crank to put it up or down only the back seems to go up not the front
Hello.
You either have a broken cable, or it may have come loose. Gain access to your anchor points and check the cables. Replacement cable can be purchased "by the foot" al Lowe's/similar as well as cable nuts and such Check the axels and spools powered by the hand crank for anything out of whack, like a broken weld on a cable drum, etc.
Best regards, W/D
Aug 17, 2009 | Coleman Campers Grill
Have used 1981 Coleman pop-up camper and the mechanism that raises the camper up is stripped. Either need manual for 1981 Coleman pop-up or any idea where to get the part to fix problem. It's the screw...
My Coleman has the same problem. I can crank the top up but it will not hold in place.
I just leave the crank handle in place after raising the top and secure the handle to the bumper with a bungee cord. It's jury rigged but it works great.
Sep 21, 2017 | Coleman 10' X 10' Sundome Tent 9160K101
Jun 07, 2009 | Coleman Sport & Outdoor - Others
Hard to crank up
May sound a bit tacky but all pop ups are a bit tedious to crank up. In the event this IS NOT your first time to own or operate a pup. I apologize and suggest you post your problem on the pop up times and or the pux webpages. Both are reliable sources for people who have pop up up or small campers.
May 25, 2009 | Coleman Campers Grill
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
Sport & Outdoor - Others Logo
160 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
