Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP Officejet 6500 install fails at 96% complete
Similar problem all over the web with no apparent fix yet. By analyzing the error logs root cause seems to be failure to register Flash9f.ocx. I tried removing all Flash from my PC, including using Adobe Flash uninstall program, re-ran HP install with no success. Still get same problem. If anyone resolves this problem, please let me know.
email - ski@skianne.com
Where is this file your say is on hps website
Posted on Jul 08, 2009
  • 31 Answers
Actually you need to just replace the file Flash9f.ocx, cause it could just be a glitch in that file. Go to HP.com for your printer and you can get the file from there.
Posted on Jun 25, 2009
MY OFFICEJET 6500 appear 0X61011beb problem , according to FAQ still fail, i just change INK, why HP printer so weak itis my second HP PRINTER, HOW TO SOLVE IT ASAP?
My printer is giving error and not general to prepare.
I call her, she ai ta general error appears she preparing and never more.
How can I solve this problem?
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Cannot coonect SCANNER (HP Officejet 6500 wireless) to my Windows
I have seen alot of problem/posts concerning HP AIO's and software issues. Typically some of the functions won't work or not recognized by solution center. Try a complete uninstall of all associated printer software, run registry cleaner if you have it, restart, then try completely uninstalling your Antivirus/firewall software. I have seen that just disabling Antivirus/firewall still causes faulty installations. Now, reinstall your printer software/drivers and connect cables only when told to do so. Some reason the AV/FW software blocks some of the AIO's apps from completely installing.
Hope this works...Good Luck!
Jun 12, 2010 | HP Officejet 6500 Wireless All-in-One...
How do I scan a document on a officejet 6500?
To scan a document using your unit, the full feature driver software should be installed in your computer.
You can download the full feature driver from the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=uk&lang=en&product=3795406&
Please visit the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=31271&tmp_task=useCategory&lc=en&dlc=en&cc=uk&lang=en&product=3795406
:) Dr Tony
Apr 12, 2010 | HP Officejet 6500 Wireless All-in-One...
Whe I install
Turn off the printer. Restart the computer then try to reinstall the printer's driver again.
Feb 25, 2010 | HP Officejet 6500 Wireless All-in-One...
Officejet 6500 error code 0x61011beb when attempting to install new printer. How to fix?
Your OfficeJet 6500 may need resetting. With the printer power on:
1) Disconnect the USB cable from your computer
2) Remove the ink cartridges
3) Unplug the power cord. Wait for at least 1 minute. Plug the unit back in (press the power button if necessary)
4) Wait for the "Insert Cartridges" message. Reinstall the cartridges
5) Close the product doors
6) If you receive a recalibration message, allow the printer to complete this task
7) Reconnect the USB cable
8) Try your print job again
If problems still exist, your product may need servicing by an authorised HP technician.
Dec 20, 2009 | HP Officejet 6500 Wireless All-in-One...
General error 0x610000F6 actually is a Carriage Jam issue
Click Here for troubleshooting.
Nov 11, 2009 | HP Officejet 6500 Wireless All-in-One...
How do i install hp 6500 all in one problem with
the installation can be done with the software disc.
if you dont have the software then in that case you can download the complete sofware which is available on www.hp.com absolutely free.
Nov 02, 2009 | HP Officejet 6500 Wireless All-in-One...
New 6500 OfficeJet installation issues -doesn't recognize printhead
you will need to contact HP for replacement parts here is there technical support # 800-474-6836 they are open 24-7
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
Fatal error while installing hp c7250. reads MSI.dot4wrp.
Very simple.Insert the printer installation software cd
First right click your cd drive and select open then go into the folder called util.
Then go into the folder called "CCC".
In that select uninstallation l3
once this uninstallation completes.
go into Local Disk C:\program files\hp\
and delete the digital imaging folder as much as can be deleted.
restart the computer.
goto hp.com and download the software for officejet 6500
After downloading it run it and when the type of uninstallation comes select advanced.
Next select custom installation and uncheck.
hp updates.
Hp Customer Participation Program
Hp Web Printing.
click on next first select usb installation and click on next(irrespective of whether it is a usb or wireless connection).
click on next and dont plug in the usb cable.
at the bottom there will be a box that says check this box if you want to connect your device later.
click on next.
the installation will finish.
Now insert your printer software installation cd and click on add a device or install and now you can choose your type of printer connection and your issue will be resolved.
" by nalin_elliot
if fails, yet try this free util for windows install repair tool on these syte
http://wiki.DjLizard.net/Dial-a-fix
Oct 05, 2009 | HP Photosmart C7250 All-In-One Thermal...
While loading HP officejet 6500 all in one encountered an error ''Fatal error 1714''
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-26831-1&lc=en&dlc=en&cc=us&os=228&product=385458
copy and paste, hp knows about it and has prepared a fix for it.
Hope this does the trick for you, good luck, please leave a rating , thank you kindly
Apr 25, 2009 | Computers & Internet
HP OfficeJet 6210 All-In-One InkJet Printer Logo
1,555 people viewed this question
Ben Johnson
