Top part of agitator appears to becoming disconnected from bottom part. bottom is attached to motor and is working.
  • 97 Answers
Hello Friend, Your problem is easily solved. You need to replace the agitator dogs. To replace all you have to do is pop the top cover off of agitator and remove bolt. Pull up on agitator and remove from washer. Next remove upper agitator from lower agitator. Inside the upper agitator top piece you will see a mechanism that has 4 little ratcheting teeth, these are called agitator dogs. Just replace them with new ones and re-install agitator. This should solve your problem. Happy to help, Tim.
Posted on Jun 25, 2009
The machine does not agitate properly
Hi There
Here some stuff for you to read and hope this will help you.Let me know how it works out.
It doesn't agitate
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Thank you for writing to fix ya.
Best Regards Richard
Dec 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills with water but then nothing, put on spin cycle water empties. The agitator does nothing
the agitator is not on properly due to worn parts under it. remove the top cap, then use needlenose to remove the cap underneath it. lift up from very bottom of agitator. look for worn areas
Oct 07, 2009 | General Electric WHDSR209DWW Top Load...
Washer had filled and agitated, but when went to spin produced a loud screeching noise. what might it be? this is an inglis front loader super capacity 2001.
It may be a a worn or broken drive belt.
OR
Some Whirlpool brands washing machines have a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index. If the bearing or cams become stripped or damaged, the mover will often not work and the cam parts will have to be replaced.
OR
It may be a bad motor.
Hope this helps.
Aug 14, 2009 | Whirlpool Inglis IP4400 Washer
The agitator doesn't seem to agitate the clothes enough
Hi, Do you know if the lower half of the agitator is moving? Is this a two piece agitator? With the washer off, try and turn the upper half of the agitator. It should turn one direction and stop the other direction. If it turns both direstions, the agitator dog kit will need changed inn the agitator.
Please let me know if this helps you orif I can assist you further.
Vic
May 28, 2009 | Washing Machines
Agitator stops working after 10 seconds
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
May 05, 2009 | Hotpoint GE VWSR4150DWW WASHER
MY WFW8300SWOO front load sport washer has emptied and will not spin, door remains locked will not open, unplugged unit for 3 hours and nothing is working it acts on it own. It has no error codes on...
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
thanks and please do not forget to accept the solution
Apr 03, 2009 | Whirlpool WFW8300SW
Agitator not turning
Mar 24, 2009 | Kenmore 22422 Top Load Washer
Washing machine will not spin or agitate.
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Nov 30, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Older kenmore washer doesn't agtat the frist load but works fine the rest of the day (has new belt) moter works fine
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
From Repairclinic
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE 90
There is a part between the motor and gearcase called a coupler, the clicking happens when it cracks. Easy way is to pull the machine foreward and tilt it back to expose the bottom. Clips hold a pump, has two hoses attached, then a motor, unclip wire harness on left and any other attached, mark these extra wires if it has them. The motor has two clips supported with two 1/4 in hex screws, Now you should see the coupler, a rubber donut and two three pronged plastic flanges attached at gearcase and motor. Use a 1/2 socket to flush the new coupler flanges on both sides and the rest is a experience.
Aug 25, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
