Question about Philips DVDR3575H/37
The clock on my Philips DVDR3575/37 jumps 20 years into future
I have (2) Philips DVDR3575/37 and they both cant keep the correct time. They both jump into the future 10 to 20 years and are the same on both machines. Is there a solution for this, Philips has stoped making DVDRs theis solution is to give my money back but I want my DVDRs, is there a way to flash the bios? by using the usb port?
  • 2 more comments
  • larryvw1 Jun 25, 2009
    Thanks
    Are you saying that I can flash the bios, if so where do I get this and how is it done. or are you saying that the solution is as easy as changing the battery?
  • larryvw1 Jun 28, 2009
    Thank you very much for you help (avid101)
    Unfortunately I can not find the links that you are referring to
    Would it be possible for you to post links to the battery replacement and to the solution to the clock malfunction
    I have opened my unit and do not see the battery it must be under a circuit board or something any help would be very much appreciated
  • larryvw1 Jul 01, 2009
    I just realized that my unit is not a DVDR3575/37
    but a DVDR3576/37 I hope this dose not make to much of a difference
  • larryvw1 Jul 06, 2009
    I found the solution on another board from "Dartman"
    You probably have the auto clock turned on and it's finding the wrong channel to set itself with.
    You can turn that feature of then it will loose or gain time according to how accurate your individual time chip is.
    Also that unit only gets the time signal from analog stations and if your in the USA those were shut down the 24th of June, if your on cable they MIGHT still be working as most still carry some networks on a small analog basic section.
    Try this place and thread, more then you want to know about that machine. http://www.avsforum.com/avs-vb/showthrea...
    I tried this and it worked.
  • 3,600 Answers
Yes you could but you need to replace the battery inside the unit to make it keep time it's the same as the batteries for mother boards.
Posted on Jun 25, 2009
  • Bruce Hathcock Jun 25, 2009
    go tot his web site do a history search and parts lookup for the battery and the fixhttp://www.bing.com/search?q=Philips+Ele...
  • Bruce Hathcock Jun 28, 2009
    I will be glad to do so but it will have to be moday before I get the info as it was him that was telling me about it.
Why does my ignition module keep going out on my 2005 Bonneville?
Frequent ignition module failure can be caused from an over-voltage condition from the voltage regulator. Check your charging voltage at the battery when the vehicle is running, and it should not be higher than 14.3VDC.
Also, improper jump-starting using a "booster" style jump-starter can cause an ignition module to fail. Did the failure occur after jump-starting? Try using a standard trickle-charger in the future instead of jump-starting your car from a booster, or simply use jumper cables attached to another vehicle or fully-charged battery.
Be sure that the voltage at the primary side of your ignition coil is no more than 6.5VDC. If it is, replace the ignition resistor.
Jul 18, 2014 | 2005 Pontiac Bonneville
After the factory-set time for the time change (which was not correct), the day-of-the-week display jumped a day so that it will show Tuesday when in fact it is Monday. How do I correct this error?
Harlyn,
Have you checked the year also. That is the only item you have not mentioned. If the year is wrong then the day may be wrong. So, you must set the time, date, month and the year, then only would you get the correct day.
Nov 16, 2010 | Emerson Smartset Clock Radio
I have a Clarion NX-500 and we're having problems with the clock. First, it kept jumping to an entirely different time (1/2 hour ahead). The guy who installed it disabled the "synching" between the clock...
http://www.teamclarion.com/Sharedwebdbs/clarionsupport.nsf/ce17209d69d0c0b688256ea0005a1fbc/70a5e00878ca4cb0882577eb005afb17?OpenDocument . follow the directions on the english pdf and it should update to the right firmware. make sure you follow directions exactly or take it to a clarion dealer to do it.
Oct 09, 2010 | Clarion NX500 Car Video Player
My clock jumps an hour ahead, how do I fix it?
Make sure that you have the clock set for the correct time zone, and that the DST feature is switched ON. If those settings are correct, try replacing the batteries. Weak batteries frequently cause an atomic clock to "jump" one hour in either direction.
I hope this helps.
Bill B
Aug 04, 2010 | Honeywell RC182WR Atomic Alarm Clock - Red
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
Clock jumping forward 3 hours
Ouch, sounds like it's TIME for a new clock
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 12, 2009 | Philips MCD708 System
Time is behind 4 hours, wont start with new battery
I inserted new batteries, second hand would not move at all. 1 hour later I came back and clock was running with the correct time.
Jan 29, 2009 | La Crosse Radio Controlled Atomic Clock
Problem: set wrong jump Cmos
Do you still have you're manual?
Go to page 1.18.
If the bios jumper is not over pin 1 & 2, than make it so.
While the jumper is on 2 & 3 you're bios clears it's self every time you boot the system. (This is why you're clock does not keep the correct time.)
Need manual? Click on the link. http://support.asus.com/download/download.aspx?modelname=P4P800-MX&SLanguage=en-us
Good Luck!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 24, 2008 | ASUS P4P800-MX Motherboard
Clock changes time by itself
If you have a govideo combo please tell me how to set the clock I have no manual.
My problem is directly above yours. Thank you.
Feb 26, 2008 | GoVideo DVR4400 DVD Player/VCR
Philips DVDR3575H/37 Logo
307 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
