Question about Ultratec Uniphone 1140 Tty-vco-phone - For Deaf
How do know you are getting a BRS VCO call? and how to answer it?
Do you pick up the handset and then press the TTY on/off button?
  • 563 Answers
You might check the owner's manual. And by the way, what's BRS?
Posted on Oct 19, 2009
  • Kayode Tayo Oct 20, 2009
    VCO is voice-carry-over. Once you get the Relay Operator, you tell them you need VCO. VCO enables you to talk to the other person instead of typing on your TTY. The relay operator would tell you when the vco is ON. You cannot get a vco on straight your TTY. Howver, if your caller is talking and you place the receiver on your TTY, what you read on the TTY is mere jumble of words/letter/numbers.
Why is red light continuous flashing on handset and station
it means you have had a call that's to let you know,
go to your handset pick up phone
push the middle button with the arrows on it.
press up to "call list"
then select the - button to the left , that should tell you whos called
then scroll throw the list until the light stops, that's who rang you.
May 19, 2014 | Philips CD4452S/05 Digital Telephone and...
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
I cannot answer the phone without pressing the incoming call button that is flashing. I want to be able to answer the phone just by picking up the phone.
From the phone, don't pick up the handset and press PROGRAM 99 then dial 22 and press STORE. Here's a problem. By default, that's what it's supposed to be and if it beeps twice when you press STORE, you didin't change it. Pick up the handset and drop it back down to exit programming.
In order to have incoming line preference, your phone has to be RINGING :-) So, if the first program didn't work, you need to see your system manager to program your phone to ring. Or find an installation manual on the internet.
Carl
May 20, 2011 | Panasonic KX T7220 Corded Phone
Phone will not ring
Is the ring volume turned up? Turn the ring volume up by attaching and plugging in the cord for the answering machine. Next leave the handset on the phone and press the up volume button with the plus(+) sign next to it.
Picking up the handset while pressing the up or down volume button will increase the voice volume.
The answering machine does not have to be on for this to work.
Feb 09, 2011 | GE 29870GE1 Corded Phone
I can hear the caller but caller cannot hear me on 29870GE1-A digital answering machine
Hi, Please check whether the mic has gone bad in your handset.
the connectivity is just fine as your are able to hear the caller. but if you think there must be something wrong with the caller's phone, try calling someone else and check.
please let me know if you need more help. Thank you:)
Oct 23, 2010 | GE 29870GE1 Corded Phone
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
I want to push the line button to answer the phone, not just pick up the handset. I have vodavi StarPlus TR 9015
Now that's an oldie but a goodie :-)
Line Preference Incoming (called PREF LINE ANSWER in Vodavi) requires system programming from a 24 button set. It's a sequence of FLASH 50 (your extension twice) and hold, then press Flex key 8 and dial 0 HOLD.
Of course you have to know how to get into system programming and try not to do anything destructive.
Carl
Sep 09, 2009 | Vodavi Lands Phones
No dial tone on my handset
when the phone rings just pick up the hand set and answer
if that doesn't work press the talk/answer button and answer
Oct 05, 2017 | GE 21008GE2 Dual-Handset Cordless...
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
Ultratec Uniphone 1140 Tty-vco-phone - For Deaf Logo
130 people viewed this question
Top Ultratec Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Ultratec Health and Beauty Expert? Answer questions, earn points and help others
