Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Wiring Schematic for an Electrolux Regency 2000
Anyone have one?
    President:
  • 1,734 Answers
Ask at manualfox.com
Posted on Sep 28, 2009
How can I get a new case for my 1990 Electrolux Regency Model 1572E? My case has cracked in many places, the top has just broken away from the hinge and the catch to keep the vacuum cleaner upright n
Yes, the Regency casings had a tendency to just "crumble" after many years of use for some reason so that exact casing is no longer available unless you find one online. If that's the case, you're best bet is to just replace yours with a rebuilt one . A lot less costly in the long run. Hope it helps!
May 27, 2014 | Electrolux Vacuums
Wiring diagram for Electrolux 4870 S2-1
You will have to go to Eureka's home page to find an electrical schematic for that model.
Nov 02, 2013 | Electrolux Vacuums
El6988a wiring schematic
see the w.diagram attached.
God bless you
May 09, 2012 | Electrolux EL6988A Bagged Canister Vacuum
Electrolux regency series upright vacuum cleaner 1572e belt replacement
Hello see the video below for help otherwise for about 20 bucks take it to as local shop Changing belt on an Electrolux upright vacuum
Nov 26, 2011 | Electrolux Vacuums
Is there a reset button for regency 2000 series vacuum power unit model 6b
There's a reset button on the power nozzle for the PN, but not on the vacuum.
If the vacuum won't come on, try the following:
Turn the top dial to the smallest dot. This is allows for finer than normal dust being vacuumed with appropriate bag fill. Otherwise, the pores of the bag get clogged before the bag is full. It still will, but not as much.
Using a genuine Aerus Electrolux bag (Home Solutions printed at top) also helps alleviate this.
You can also check out my tip at:
http://www.fixya.com/support/r7367127-electrolux_epic_6500_trouble_shooting
Jan 06, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Dec 30, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Eletrolux power head
Usually you will find a brush assembly which includes the bearings. You could also be hearing the belt jumping across the brush gear if the belt is bad. If you order the parts online, you may want to get a brush and belt, since a belt won't be that much more money anyway. Aftermarket Aerus (formerly Electrolux) parts can be suspect sometimes, so I would suggest finding a dealer. You can go to their website to find the closest store. aerusonline.com Good Luck!!
Oct 20, 2008 | Electrolux UltraLux 2000 Bagged Canister...
How do i open a electrolux ultralux 2000
If I am right, there is a strip down the middle, on each side, they slide off then, the 2 halfs will come apart.
Jan 15, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Sep 15, 2007 | Electrolux Lux 5500 Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
363 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
