Question about Water Heaters
I nee the manaul for rinnai 26 solar
I need the manaul for rinnai 26 solar
  • 332 Answers
You can go to the rinnai web site and down load this,, they are available on line,,
Posted on Jun 27, 2009
Relighting sunmaster 26 solar hot water service after gas being turned off to house
see if pilot light unit or electric ignitor if no pilot area on gas valve then ignitor if pilot section relite
Apr 22, 2018 | Water Water Heaters
My rinnai 26 infity gas hotwater heater keeps changing tempreture whilst showering.
Bosch has a 'fluctuating temperatures' pdf
It may apply or not
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 04, 2011 | Rinnai Water Heaters
I Have a rinnai 26 has been working for 3-5 years now, just stoped. looks like the poilet light is out, can any body lend a hand
Firstly this unit has no pilot light, it lights automatically when you turn a tap on. Many reasons for it not working. If it just sits and does nothing when you turn a tap on you need to start with the flow turbine or a electronics fault on the PCB. Really recommend getting an expert in, too many things on these that can cause this fault. Sorry to be blunt.
Nov 27, 2010 | Rinnai Digital Remote Water Heater Control...
I need a service manual for a Rinnai Infinity 26 continuous flow hotwater system - REU-VR2626WG-AK Can you help me? Linda
I left Rinnai only about a year ago at a levle of State Service Manager. I had been asking for service manual for for many, many months. Basically as far as I am aware there is not a service manual for the WG. If you google Rinnai Infinity 26 manual you can get a PDF from the Rinnai NZ sales site but his dates baack to 2003. Unfortunately there are major changes to some of the components but it might be better than nothing. Just don't use part numbers, and you might find bits to check that now have voltage and resistance differences. Send a message to Rinnai complaining, I encouraged people to do so even when I worked for them!
Aug 26, 2010 | Water Heaters
How to operate Rinnai V1500 water heater?
The V1500 is in essence the same as Infinity 26. Rinnai have manuals on their website.
Here's a link
http://www.rinnai.com.au/images/stories/operating_instructions/Hot_Water/All_Continuous_Flow.pdf
If you have any specific problems or queries just post them on this site. I check it every few days.
Cheers
Aug 15, 2010 | Water Heaters
Hi, our plumber has hooked up a new infinity xr-26 but the existing remotes don't work. He says it's a simple 2 wire connection but ther's no cirrcuit
Check with Rinnai to see if the old remotes are compatible with the new heater. Might mean upgrading the remotes too but the wires should be OK. Double check that he has actually connected the wires to the heater. Rinnai in Australia recentyl changed the connection point for the wiring. I can help further with this if this is the issue (not sure where you are!)
Mar 07, 2010 | Rinnai Digital Remote Water Heater Control...
My Rinnai 26 sometimes takes 10 minutes to start
This is not an uncommon problem. You may notice this problem particularly if you haven't used hot water for a period of time. The hot water heater is probably working, but there is quite a bit of water that has to clear out of the lines before the hot from the heater reaches your appliance. I suspect that the water heater is doing its job, and that is the assumption I am going off of for my next statement. A recirculation system will work well to eliminate your problem. Again, assuming that the hot water heater is in proper working order. I would do my research on recirculation systems before buying one. Often times you get get a relatively inexpensive unit that will do the job for you.
Nov 18, 2009 | Rinnai Water Heaters
I need the manual for a Rinnai Infinity 26 hot water system
you can get it off the rinnai web site they have a spot on there to get the internet manuel,, but from what you are saying you may need to adjust the thermostat, or the temp, remember even though you will have endless hot water it still takes the smae amount of timed for the hot water to get to your faucet,, not only that make sure your shower heads aren't holding back to much water pressure, if you don't have enough water going thru the unit it will not stay lit, if will come on and go off, judt to dstisfy the unit,, make sure the filter is clear, on the cold side there is a cap screw if you take it off there is a screen in side you just pull it out and clean it and reinstal it,,
Jun 25, 2009 | Rinnai Digital Remote Water Heater Control...
Water Heaters Logo
77 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
