Question about Canon CLC 1000 Color Copier
Canon color laser copier
Error E020 on Canon CLC 300
  • 163 Answers
E020 is a toner feed problem to the developer. First, check for broken gears or missing teeth on all the developers. That is usually the cause.
Posted on Nov 06, 2007
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Dec 04, 2009 | Canon CLC 1150 Color Copier
I have an older Canon clc 900 Error E020 Switch power on and off again"displays when trying to copy. When I turn the copyer off and on again the same message displays.What to do ?
Error :
Intermittent E020 / E061 codes.
Workaround :
It's possible that there is a poor drum ground from the static eliminator brush. You may need to replace the static brush with the drum grounding leaf spring from a CLC 350 (part numberFA5-9308-000). Follow the procedure in technical publication CTP.NO 700/800-69.
Error :
E020 sub code 0440 and light density on all colors
Workaround :
Check the developer assembly movement, i.e. up & down and that the magnetic roller is turning. Check the EPC readings, laser output, fold back mirror, and the connectors for the developer and the developer bias contacts. If all the above checks are good, then the problem can be with the AC voltage output of the developer bias HVT. The DC-voltage for the developer bias is split between two colors ( magenta & yellow ) or ( cyan & black ). The AC voltage is supplied for all four colors and it's loss will be seen in all the colors whereas the loss of the DC voltage would affect only two colors. To fix the problem replace the developer bias HVT part # FG5-3068-060.
Oct 18, 2009 | Canon CLC 1150 Color Copier
E020,0173 error for a clc 1150
call in a service technicail for that type of copier and you mayspend lots of time and money trying to fix every little thing i ell you
Feb 03, 2009 | Canon CLC 1150 Color Copier
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
Jan 13, 2009 | Canon CLC 1150 Color Copier
E020 02FF Error
the problem this in tolva of cian
Sep 05, 2008 | Canon CLC 1120 Color Copier
Error Code 0181
I did not see that error code on Canons web site. It may have something to do with the laser or a pinched wire with one of the lasers. Also, which color is giving you a E020 code? It may have something to do with the other.
Feb 06, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1000 Color Copier Logo
224 people viewed this question
old marine
old marine
