Question about GE Microwave Ovens
My ge microwave quit working while i was cooking in it. it is if a breaker blew but none did. i plugged it into another outlet and still no power. does this microwave have a fuse or reset button? it is model # HVM1540SNSS
  • GE Master
  • 9,098 Answers
The parts I would suspect are (in order) the TCO (aka thermal cutout / thermostat) located on the magnetron, the TCO on the top of the oven cavity, the bottom TCO (not to be confused with the hood TCO, which should read open), or the 20A ceramic line fuse, which is likely to be located on a filter board near where the cord comes into the unit.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
my ge microwave quit working while i was cooking - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
It is vital that the internal cooling fan runs whenever the oven is cooking, or the magnetron will be destroyed.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Posted on Jun 28, 2009
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
New microwave stopped working after 15 seconds
Possibly the fuse / breaker is tripped, usually all outlets in one room share same breaker. Check breakers (or fuses) or try outlet in differnt room. If the outlet has power, (plugin a lamp to check) and the microwave still does not work, take it back to store for replacement or refund.
May 11, 2013 | Oster OGG61403 1.4 Cubic-foot Digital...
Power failure on ge wes1130
Power being interuppted could be anything from a bad fuse , bad fuse holder, bad solder connections on the main board. Bad breaker in your panel. Start by plugging it into an outlet you know is on a different breaker than the on it is on now. See if it does the same thing. If it works ok, then problem with power to the other outlet. If it does the same thing problem inside of unit. PF is Power Failure, now we have to figure out why.
Oct 15, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My daewoo microwave/toaster blew my breaker upon resetting it and plugging in the microwave it blew again then it tripped my GFI what could be the problem?
Probably a short inside the microwave circuitry.  I had a Daewoo and had nothing but trouble with it.  Main board went out in a year, then again in another year.  Finally went to Home Depot where I bought it and was told that they had nothing but trouble with them and quit selling them.  Now I have a GE Spacemaker.
Apr 22, 2009 | Microwave Ovens
My GE spacesaver oven JVM230 quit, like a fuse blew. No over the stove light, no exhaust fan, nothing. I checked the circuit breaker and pluged in an appliance and it worked. The plug is okay. Jim
This is almost certainly a blown thermistor. This device is located at the air outlet on the microwave. This is a thermally sensitive resistor that cuts power if the unit overheats for safety. It can fail because of age also. Replace with the save value unit. You can get this part from electronics stores like Radio Shack.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1640SJ
click on your model number. Then on the next page you can select diagrams to look at.
Mar 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 09, 2008 | GE JVM1190 Microwave Oven
Microwave Ovens Logo
239 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
