I have a 60 inch WEGA Sony TV LCD Rear PRojection. We just moved. Every time I turn on the tv it stays on for 3 seconds and then shuts off and the red stand-by light blinks. Please let me know how I can fix the issue. If this is a bulb issue, can i do this myself.
  • 10,594 Answers
I need to ask couple of questions for your Sony 60" TV problem to provide solution.
1- What is exact model number of TV as it would be written on sticker pasted at back of TV.
2- When TV shuts off, its standby light will blink as error code. There would be interval of 3 seconds between blinks. Please count LED blinks and let me know.
Hit "add a comment" button to reply.
Thanks.
Posted on Jun 25, 2009
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a sony wega 60" projection tv, and everytime i turn it on, it stays on for 3 seconds then turns off again...plzzz help!! thanks
Hi:
If you have never replaced the lamp then I would say its time for a change, Replace your lamp and you should be fine. Lamps only last about 6500 hrs , thats a little under three years, so if you have'nt had a lamp replacement in the last two years this is your problem.
Aug 24, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv will not stay on
If tv shuts off and turns back On itself than lamp is weak and need to be replaced.
If tv shuts off but does not turns On itself than you will see red light blinking on tv front, let me know how many times it blinks, there would be pause of 3 seconds in blinks so count pause to pause and post here to provide you helpful info about problem.
Thanks.
May 24, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a 60' sony wega r60xbr1 i just had a new light engine installed last night the tv was never turned on afterwards . I turned it on the screen come on shut off imediatly the red led flashes 4 times...
LOOK IF YOURS IS A SONY I had a sony grand wega 60 inch with the same problem as many tv turns on shuts off the red led FLASHED 4 TIMES. it is a heating issue if one of the three fans inside are not turning when the tv is on even on the first few seconds of turning it on the tv will send a fault code of four flashes . Then the tv shuts off so it wont burn its self up or damage the optical block. all with this same problem of 4 flashes take a flashlite and make sure your fans are turning if not that is your 4 flash problem. I hope this helps someone and if it does i have done my job .
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
TV stays on for few mins and then turns off
IF its the lamp for Lcd. Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Part # is xl-2200 found it here: http://www.discount-merchant.com/SearchResults.asp?Search=XL2200+?Click=48173 God bless you!
Nov 17, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have the sony wega 60 lcd tv, it turns on ok then shuts off
How long have you had the set? If its been at least two years then its time for a new lamp.
Thanks
you can email me at Delhielectronics@live.com
if you need futher assistance. I believe your lamp is faulty...
Sep 26, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Ticking noise from TV - Sony 50' rear projection 1080p LCD
The problem is ht leakage . remove the ultar cap of the tube and clean both the tube and cap with wd 40. then reinstall cap using some silicon glue.
this will correct your fault.
Jul 11, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
