Question about Kyocera Mita FS 1010 Laser Printer
Kyocera Mita FS1010 fault
The Kyocera Mita FS1010 has a permanent orange light on the 3rd row down - paper feed roller ?
Checked internally - all looks OK, cartridge new, no jams apparent.
Any ideas ?
  • 622 Answers
Check your user guide... it will explain this error... or contact kyocera customer support...
Posted on Dec 24, 2009
2 Suggested Answers
  • 2427 Answers
SOURCE: The Kyocera Mita FS1010 has
this occurs when the paper feed roller or the fuser needs to be replaced, The rollers are considered consumables and similar to that of the toner and fuser they need to be replaced. Get them at the same place you get your consumables and follow instructions on your manual to replace them..
Posted on Nov 02, 2010
Paper jam error
This error apear usaly on this machine , when the cloutch sistem of paper feed roller are obsolete , to fix this issue you must clean the sponge out the clutch or replace-it becouse this is already sticky
Feb 02, 2014 | Kyocera Mita FS 1010 Laser Printer
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
Paper with notes in pencil went through printer, now all printouts have imprint of pencil notes on them. i printer ruined, what di I do to correct this? Printer is Kyocera Mita FS-1020D
go look at the orange rollers in the back and see if the letters are etched into your fuser... if it is then replace fuser... otherwise... replace your drum
Nov 12, 2009 | Kyocera Mita FS-1020D Laser Printer
Kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
FS-1030D 3rd light amber cant see any paper jam
just needed good clean inside and rollers cleaned
Feb 06, 2009 | Kyocera Mita FS-1030D Laser Printer
Auto paper feed jamming
clean the rollers with alcohol. this will renew the rubber and clear up the problem
Jun 27, 2008 | Kyocera Mita KM-2530 Laser Printer
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Kyocera Mita FS 1010 Laser Printer Logo
604 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
