Question about LG LSC091PMA Split System Air Conditioner
I have a split air conditioner my out fan keeps
I have a split air conditioner my outdoor fan keeps turning on and off shouldnt it stay on when the t-stat is calling for the ac unit to turn on shouldnt both indoor and outdoor fan stay on not just the indoorfan stay on by itself thanx for reading.
  • 3 Answers
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Posted on Jun 25, 2009
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Air conditioner fan will not turn on outside. Rudd model# UPKA-025JAZ
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. bobicehouse_41.jpg
If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor.
Jul 22, 2011 | Ruud Matching Split Air Conditioner
MY LG SPLIT A.C 1.5T ONES HAVING EXCISSIVE SOUND ON OUTDOOR UNIT Purcheses on may 2011.
hi,
The bearing of the outdoor fan have some problem that's why it makes noise. Try to put some oil on the shaft of the fan. if then also the sound remains you have to replace the bearing or the fan as a whole.
ok
Jun 09, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My outside unit for heating and cooling keeps kicking on fan and turning off every 45 seconds or so. What could be problem
It's communication error between indoor and out door.As you don't mention any error code, normal causes for your a/c problem may be one of this.
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
or
Jan 09, 2011 | Heating & Cooling
When calling for heat the outdoor unit fan cuts off and the compressor stays running after about forty seconds.
Actually, for heating mode, the condenser fan works on pressure build up by Fan pressure Switch. If pressure less the fan won't run.
Dec 08, 2010 | LG Art Cool LA181CNW Split System Air...
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
Outdoor A/C unit fan
If the fan and compressor are shutting off. its possible its cycling on a low pressure switch. probably low on freon.
or you have a low ambient kit to keep pressures up during low outdoor temps while ac is running just the fan will shut off, however thats not a typical thing to have a residential system
Sep 20, 2009 | Heating & Cooling
DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Apr 16, 2009 | DeLonghi Heating & Cooling
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
AS12S4GB AIR CONDITIONER 4 BEEPING
when you restart the unit monitor the outdoor unit and see if the compressor and outdoor fan starts up . before the beeps . you can try reseting everything by disconecting all power to outdoor unit .
hope this helps please leave fead back / keep me informed
Oct 20, 2008 | Samsung AS18A6RB Air Conditioner
LG LSC091PMA Split System Air Conditioner Logo
405 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
