Question about Microsoft Xbox 360 Console
3 red lights flas when power is turned on - Microsoft Xbox 360 Console
  • 15,935 Answers
You have what is known as the xbox Red Ring Of Death aka... RROD.
If you are the original purchaser - Microsoft is fixing them for free (but you will be without your XBox for about 6 weeks.)
Basically - the RROD is from not enough thermal compound between the heatsink and processor. It overheats and goes into 3 light error mode.
There are sites that will fix (for a fee) and even videos on YouTube that describe how to fix it yourself if you are inclined to do that.
It entails opening up (and voiding your warranty) the 360. There are so many hidden screws and latches - it is imperative to find a video or step-by step instruction on opening it properly.
I would suggest sending in to Microsoft so your warranty is not compromised.
Otherwise - see THIS SITE for step by step instructions on opening, cleaning, and replacing the thermal compound.
Other places can be found simply by googling "RROD FIX" or try YouTube and look at some "RROD FIX" videos.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 25, 2009
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
Red light keeps coming on and green one keeps flashing
is both light flashing alternately? if yes, it means you need to replace the waste ink pad and reset the waste ink counter...
May 20, 2010 | Epson Stylus C62 InkJet Printer
Iplaying my xbox when flas red ligh but I connect other control after turn off I disconnect and connect but not more work
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
Jan 18, 2010 | Microsoft Xbox 360 Console
N73 flas light problem
It cannot be turned off because it is an automatic setting already employed on the phone.
Jun 29, 2009 | Nokia N73 Cellular Phone
Samsung TV Turns off after a few seconds red and green light flas
You are going to have to troubleshoot all the boards in the television until you find the problem. Start with power supply board. This part usually goes bad due to overheating and faulty components. You must check for brown spots on the boards , that are signs of overheating. Look for bad components like bulging capacitors and burnt resistors.Look for bad connections, like cold solder joints. you must be very careful working on the power supply board as it does have high voltages they can be very dangerous to the inexperienced user. Never test anything with the power on or connected.Use anti static protection straps and gloves around all the chips and microprocessors to avoid damaging them. Check all the other boards for the same problems. If you can find no problems, Then it is time to get help from a service center where they will have all the necessary testing equipment, To give the unit a more thorough testing for faulty components.Hope this helps you with your problem.
May 17, 2009 | Samsung DLP HL-P5663W 56" TV
S730 flash doesn't work
well that happenes to em all the time, u just need to either hold it down a little bit longer, or it might be that the memory is ful.
Aug 01, 2008 | Samsung Digimax S730 Digital Camera
Microsoft Xbox 360 Console Logo
91 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
