Question about Toshiba 55H70 55" Rear Projection Television
Vertical Rolling picture
My Toshiba Rear Projector continuously has a rolling picture from top to bottom on both TV & DVD or VCR viewing.. Not sure how to fix the problem
  • 934 Answers
Vertical IC, caps or the hyper board would be my guess. None of which you can do yourself without some serious electronics experience. You'll need to ESR test the caps in the vertical circuit first, then move-on to static testing the vertical IC. If either of these are the problem it's not too expensive. The Hyper Module is a different story, usually only replaceable as a module but you can also send them in for rebuild to PTS Electronics.
Posted on Nov 05, 2007
Yeah I have a Sylvania model # SP A2751 106. It is a old **** tube tv. When I go to hook up the the dvd player and switch it to vcr/aux the picture rolls in bars upwards. Its not the dvd player tried it on...
There should be a preset resistor on circuit board of old CRT based TVs, designated as vertical rolling adjust. Try to locate it and adjust a little till rolling stops, while playing the DVD. The set will be live during this process, so be careful. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 25, 2013 | Televison & Video
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
Good day: Our Tv picture is rolling when
Either the tracking will be off set on the VCR or the heads may need cleaned or the pinch roller in the VCR will be worn & need replaced.There could also be a possibility the guide arms are not fully in position in the VCR.
Oct 23, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Toshiba CX32G60 1/2" vertical inward bow center of video
change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Nov 30, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Vertical rolling of picture
If the picture rolls while both on cable as well as when you playback a tape or DVD, it could be caused by a bad filter capacitor in the power supply or vertical deflection circuits. If it only rolls while trying to view a picture from a cable/satellite box, then that component is likely at fault.
Aug 20, 2007 | Hitachi 60EX01B 60" Rear Projection...
The picture on the VCR keeps rolling. How do I remedy this? I have a Sylvania cca-132a2 model.
i know this may seem old-school, but try turning the vertical hold knob. it used to solve all vcr problems with rolling picture.
Jul 07, 2007 | Sylvania (SRDD495) DVD Player/VCR
That is not a vertical roll from side to side, this is a horizontal rolling. if the vertical had a roll it would be going from top to bottom. This is most likely a coupling between the horizontal sync circuit and the sync separator circuit. Good Luck
Jun 28, 2007 | Sony KP-53S65 53" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
