Question about NorStar M7208 Corded Phone
Intercom on one of the office phones has stopped working?
Press Feature * 0, then press the button you think is the 2nd intercom button. What does it say on the display?
Chances are that the button got erased. Do you know how to get into system admin programming?
Posted on Jun 25, 2009
All of a sudden, I Problem with the NorStar T7316E Corded Phone (nt8b27jaab) All of a sudden, I can call to other intercoms in the office, but they can not call me. Do you know what has happened? Also...
What happens when someone tries to call you ?? Does it blink on the intercom key ? Are you sure they're dialing the right extension number ? Go to your phone, dial FEATURE *0 and then press the intercom key. It'll tell you the extension number of that phone.
Other than DO NOT DISTURB (feature 85 = on, Feature #85 = off) there's nothing that would stop a phone from getting an internal call.
May 10, 2011 | NorStar T7316E Corded Phone
Intercom / page problem with AT&T phones model 944 and 955
Do you have DSL on this line? Make sure you have filters on the lines going to the phones or take the line coming out of your DSL modem and split it to the phones.
Also, try unplugging your fax, computer modem or credit card machine and test the intercom. Sharing one line for several devices can make the intercom unhappy.
Feb 21, 2010 | AT&T 944 Four Line Intercom Phone
We use an RCA 25415 in our office and can not get the intercom to work, any suggestions?
http://www.rca4business.com/products/pc/pdf/instruction-book/25415RE3.pdf
If you click on the above that is your manual.
go to page 10 for Intercom auto answer.
and page 19 for Intercom calls .
Hope it helps!
Jan 12, 2010 | RCA 25415RE3 Phone
HOW TO ''INT'' THE ENTIRE OFFICE
This is a partial guess, because an EKT phone probably sits on a Strata. Try Intercom 60 for all internal, 68 for all internal/external if you have it, and 69 for external only. The missing numbers are 1-4 for zones.
If it happens to be a DK, try 3x instead of 6x.
Carl
Mar 23, 2009 | Toshiba EKT 6010 S Corded Phone
PLEASE, PLEASE try and help me...I can't tell you how much this would be appreciated. I have a Panasonic KTS4100 4 line phone (2 corded phones in our office, and one cordless). I have NO IDEA how to use...
Just in case you missed the manual:
http://www.centralcomms.co.nz/pdf/KX-T2375-brosh.pdf
There are 2 conditions you need to be aware of
1 No DSL on the line
2. Set the intercom extension of the second phone
By default, both have been assigned ext 11. The intercom uses the same frequencies as a DSL line to transmit, so that could be the noise you are hearing.
Page 23 tells you how to set the intercom extension, and the DSL warning is almost at the bottom of every page from 18-22.
Carl
Nov 25, 2008 | Lands Phones
Re: Question
Your phone can have 3 options, Ring all the time, Switch between Voice and Ring, or Voice all the time.
From your phone(s) press PROG 21 and press the ENTER soft key (3rd key). Now press the SEL (3rd key) until it says VOICE CALL then press ENTER and EXIT. If you set it to this mode, the AUTO ANS button won't work.
If you select TONE, the Auto Answe button will work, making the phone VOICE CALL when lit and ring when not.
If you select VOICE CALL DENY, the AUTO ANS button still won't work and ...you get the pattern.
Carl
Oct 22, 2008 | Panasonic KX-T7633 Corded Phone
Phone ringing after power failure
I believe you have to reset the intercom system, meaning you need to reassign one or all of the phone's intercom numbers. To assign intercom # ( found on page 10 of the manual which you can download online)
1 Do NOT lift handset
2 Press the following 3 buttons (in order) PROGRAM, STAR, and then POUND
3 Enter two digits (the number you want the phone to be)
4 Press the INTERCOM button and you will hear a tone - then youre all done.
Aug 03, 2008 | AT&T 954 Corded Phone
How do I turn off the intercom to my phone
Hi Andrew,
Press [feature] [8] [8] to prevent your phone from receiving the intercom
Brian
Apr 01, 2008 | NorStar M7310 Corded Phone
Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
Dec 28, 2007 | Avaya 700340193 Corded Phone
Problems with Intercom
Yes, you just need to program those buttons on your phone. Press "feature" then "redial" then press the button you want to program, then press "1" then it's extension # (example: 1-0-0 to program the button for extension 100) then press "feature". After you've programmed those extensions, the intercom should work.
Dec 20, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NorStar M7208 Corded Phone Logo
181 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
