Question about Beyerdynamic DT 531 Consumer Headphones
I have a set with one ear piece working
Do you still have the broken set. I need one ear piece working cos one of mine is bust. I was wondering if you would sell your broken set to me so i can make one good set out of two dodgy..
  • 54 Answers
I don't have one, but are you sure the ear piece itself is bad? Usually, the problem is in the plug, cord, or termination at the ear piece. Troubleshoot with an ohmmeter (pocket DMM has one) and repair with a soldering iron.
Posted on Jun 25, 2009
Just moved to new location and hooked up i com. Am only getting sound in left ear. Have rechecked everything and all connections seem sound???
this is an oxmoron you cant have checked every thing
left and right ear audio on CBs come from a common mono signal
so the right ear signal is missing or the headphone on the right ear piece is busted
sherlock....
Nov 27, 2014 | Icom Ptt Over Ear Mic / Ear-phone For...
Rubber holder that goes over the ear has broken. Can it be replaced and how? Bluetooth still works find.
Hi cptpatterson,
  • If you have the rubber holder broken , then you can stick it carefully with superglue and it should work fine, but make sure that the glue does not go in the ear piece which can affect the ear piece and would not work properly.
  • There are spare rubber holders available at an authorized Nokia Shop from where you can get it , but I would suggest if you want to save money you can just use super glue in small quantity and use it at the broken surface and it will work find for you as this device does not need a huge amount of strength that it has to bear.
Hope that helps..:) Let me know in case you have any queries, your feedback would be appreciated.
Sep 12, 2011 | Nokia BH-200 Wireless Headset
Hesh DJ Headphones one of the cables in the connections have come loose so only one headphone works. where can i get it repaired?
my skullcandy headphones speaker bust a while ago so i replaced both of them, so its the same concept of changing wires or wateva(cos i had to change that to as i wanted to extend it.) its alot more complex then it looks, but mine came out fine, so if you cant find a place to fix it it is possible to do it yourself, note that the screws are under the ear cushion witch can twist of.
Jul 09, 2011 | Skull Candy Hesh Stereo DJ Headphones -...
Left earphone keeps dying out and comes back. Also the red light on the mic keeps coming on which blocks me from talking online.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The problem with this wireless! head set cutting out on the left side is very common for this model. I fixed mine by removing the soft ear cup then the two screws under this cup then carefully pry that top piece off the next lower piece. It will come but it is stuck with some soft glue.
Next, unsolder the two wires on the back of the speaker taking note of the polarity. These wires are what are broken. Undo the screw in the center. With a small screwdriver carefully pry the pivoting cup off the ear piece. It is snapped onto a small ball joint under the screw.
Now remove the four screws and remove the top of the ear piece.
Remove the two screws from the small printed circuit board and unsolder the two speaker wires. You will need to find some new wire that is flexible and not much bigger in diameter. I used some that was too large and had trouble getting the last cap that holds the soft ear cup back on. I also reamed out the holes in the cap and the cup that the wires go through to give them more movement.
Replace everything and solder the wires to the speaker in the same order as removing.
You will need a good small tipped soldering iron.
Good luck
Calvin
Feb 10, 2010 | Logitech Clearchat PC Wireless Headset
Over the ear piece broken on my hfblu-1k cellular
You can get replacements by calling 1-732-912-2000 and follow the directions on the menu. Listen to the choices and you should be good to go. Ask for Tech Support # 216.
Mar 08, 2009 | Cell Phones
Have 3 jabra bt 135 earpieces and the earhook is broken snappede on all 3 where can i get replacements
Same thing happened to me. For about $5, I went to Home Depot and bought 24 gauge wire (about 5") and a pack of black heat-shrink plastic sleaves (1/8th inch or 3/16) from the electrical department. The 24g wire fits perfectly through the rubber slot after you pull out the broken ear hook. Use a pair of pliars to bend the wire to shape your ear (use the broken jabra ear hook as a template). Once you have the right shape and have filed down the sharp edges, slip the heat-shrink plastic sleave over the wire, making sure you leave the end piece that goes into the slot of the headset as bare metal. Use a hair-drier on high-heat to shrink the black plastic. Mine has worked perfectly for over a year and actualy fits better than the original.
Dec 08, 2008 | Jabra Bluetooth Headset with Adjustable...
The ear loop attached to my logitech F-0399A bluetooth headset has broken into 2 pieces. Logitech says since I didnt save my receipt, they were at a loss to do anything. Earphone works, I just need...
Ok, You can purchase an replacement part for the next generation logitech travelller Blue tooth. They fit fine .
If you cant find a replacement for the logitech travelller BT set, ask support to send you one and say you will pay up.
If you do buy , get a couple more
Else buy some gorilla glue and follow instructions to make a solid bond,
Bond one piece, Set aside for 12 hours,
Bond another piece and set aside for another 12 hours or over nite... The two pieces should now be solid bonded
Oct 12, 2008 | Logitech 250 Headset
Pantech duo only works on speakerphone!!
i had the same problem it can only be fixed by repair. the internal microphone has broken
Mar 24, 2008 | Pantech Duo Smartphone
My katana's ear piece doesn't work
no solution - same thing happened here.
junk
Feb 15, 2008 | Cell Phones
Beyerdynamic DT 531 Consumer Headphones Logo
263 people viewed this question
Top Beyerdynamic Audio Players & Recorders Experts
Ben Armstrong
Alan W Kelly
Alan W Kelly
Are you a Beyerdynamic Audio Player and Recorder Expert? Answer questions, earn points and help others
