Question about Focus Electronic Focus FK 2001 PS (FK2001PS) Keyboard
I just bought a used 2001 clicky keyboard, and the g and h keys are transposed. How do I get the caps off to fix? Thanks.
  • firstluff
    firstluff Jun 26, 2009
    I wound up using an improvised key-removal tool: two unfolded paper clips, each with a tiny hook bent into one end. The hooks were slipped down to engage the diagonally-opposite corners of each keycap and lifted to remove the cap. Worked well without the danger of breaking the caps.
  • 20 Answers
Carefully take a small knife such as a butter knife, slip it under the key and pry it up, be sure that if the key is resistant that you do not break it. kids at my old school use to do that in the computer lab all the time, immature and idiotic.
Posted on Jun 25, 2009
Is there a way to program the whole keyboard to play 1 octave lower?
You can use TRANSPOSE/SETTING button.
Each press the TRANSPOSE/SETTING button cycles through the setting screens. If you accidentally pass the screen you want to use,keep pressing the TRANSPOSE/SETTING button untill the screen appears again.
To lower by one octave,set the value to -12
You also can use PIANO SETTING button.
Find the setting in page 07 of PIANO SETTING.
Sep 03, 2015 | Casio CTK810 61 Key Keyboard
I have my sound banks layered. My first bank is piano on top and acoustic bass on the bottom. Last night it started to detune. When I hit the C key, the piano would play a C, but the bass bottom layer...
Sound banks does not define what keyboard you might have... HOWEVER... THINGS TO CHECK: Check if the bass MIGHT have a transpose set by mistake. Also check if pitch bend might be active... some keyboards can use a pitchbend pedal... We can't guess what brand or model keyboard you have. Batteries are NOT anything that would cause this. Remember that on a keyboard there is a LIMIT to the number of sound generators that are available and you can run out of polyphony with mass layering. The last thing might be any "effects" you have activated. It sounds like you can split this keyboard so separate transpose MAY be possible that low end is transposed while upper is not...
Sep 07, 2011 | Music
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Jul 26, 2011 | Yamaha Music
I have Casio Ctk-496 and I have MIDI-USB wire. It all works, but Transpose button doesn't transpose and casio chord doesn't work with my computer. And all is still working even if I pull out IN wire from...
Casio Chord is internal to the keyboard and doesn't come out on MIDI. Transpose is similar and while the button may send a MIDI transpose type signal out, the notes will not transpose in your computer...
Mar 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Brand New Axiom 25 most keys do not play
use on screen keyboard and type your keys if this work then it is hardware problem if not then it is a virus scan it
Mar 27, 2010 | M-Audio US85100 Keyboard
Recently bought an Acer desktop. The keyboard has a couple of issues. Firstly the " and @ on the keyboard are transposed on the screen - ie I press the @ key and I get the " symbol on screen. Also the...
Your regional settings may be UK but the keyboard setting is USA..
Go back into Control Panel/Regional and Language Options/. Click on the language tab and then the language button and alter the keyboard language there to UK
Oct 03, 2009 | Acer 91.63X07.001 Keyboard
Problem of keyboard keys getting transposed.
Your region and language settings are incorrect.
Go to control palel/Regional&Language settings/ use the drop down menu to select the correct region then click on languages tab/details and do the samme. apply and exit.
Sep 23, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Transpose feature on the Roland RD-600 digital piano
If you want to play in C and carry the sound of Bb,
1. From C, count down two half-steps to Bb
2. Press and hold the Transpose button and press the key on the keyboard that displays through the window, "-2"
3. To turn off the transpose feature, just press the Transpose button again.
Feb 23, 2009 | Roland Vs-2000CD Digital Studio...
Two keyboard keys seem to have been transposed
Yes when going through the setting up procedure for your new computer you should have installed the British keyboard instead of the US one.
Doing the above will correct your problem.
Nov 09, 2008 | Computers & Internet
Focus Electronic Focus FK 2001 PS (FK2001PS) Keyboard Logo
189 people viewed this question
Top Focus Electronic Computers & Internet Experts
David Payne
David Payne
Are you a Focus Electronic Computer and Internet Expert? Answer questions, earn points and help others
