Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana SR520SSide by side fridge freezer: How do I take off the dm
Amana SR520SSide by side fridge freezer: How do I take off the door frames to change the decor panels?
  • 15,935 Answers
CLICK HERE for a PDF version of your use and care manual.
CLICK HERE for Installation Manual.
Page 3 of the installation Manual has the instructions on removing the doors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 25, 2009
GE side by side. Water leaking from bottom of freezer door. Fridge is cold. Freezer is fine. Ice maker fine. Only problem is the leaking water
It means that the freezer door is not closed will see the rubber frame it maybe broken some where or twisted .
If it's broken it must be changed but if it's twisted you can use some medical cotton roll it by your hands like a pen and insert it behind the frame.
I hope that help you. so sorry for my bad English.
Feb 12, 2013 | Freezers
Humidity signs in freezer
check to see if your seal around the fridge and freezer is good and tight. hope this helps you
Feb 04, 2013 | Amana Refrigerators
Amana SZDE27MPE
check the gasket fist if it's ok check the closure.there's a door closure on the bottom of the door and hinge that wears out and needs to be replaced,is the fridge door when closed side by side lower than the freezer door?it's plastic,here's a picture
http://www.repairclinic.com/PartDetail/Closing-Cam/R0181181/1035
part number R0181181 but call your local parts store and give them your model and p number or manufactures number and they will sell you the correct part,on some kits they give you the cams,shims and new screws,as for the drip pan overflowing,this is most likely from the warm air getting into the fridge melting out the frost on the coil or ice,usually when this happens the air ducts freeze up and the fridge section gets warm because the dold air from the freezer can't blow over into the fridge side because the air ducts are filled with ice,shut down the machine or unplug it,remove everything from the door,remove the top screws and then tilt out the door and lift up,put the door on it's side and change out the cams,it's usually a 5/16 inch screw holding them in place and then put it back together,while you have the door out check the gasket,any rips or anything change it out.hope this helps and good luck.
Aug 27, 2012 | Amana Refrigerators
Amana fridge side x side SKD22S2L. The Door frames are really "Hot" mainly the center frame on the side by side. I cleaned the evaporator coils and seamed to help a little but still getting hot.
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Feb 07, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
Oct 08, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kitchenaid fridge #KSCS25INSS hot door frame
There are heaters located inside the door frame, to prevent your doors from freezing shut, and also to prevent condensation on the outside of the appliance. It sounds to me as though that is where your problem is... Hope this helps
Sep 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Bottom freezer door off tracts.
Yes, parts are available. Click here for a full size diagram and click here for parts.
SG
Apr 07, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
178 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
