Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Was installing satellite cable and leaned on back of TV, heard
Crack sound. Picture now has green square and several vertical lines. Can this be repaired inexpensively (under $200)?
  • 54 Answers
If the sound came from the rear as you were attaching the cable, probably yes. If it came from the front, it may have been the display panel, and that would cost a good deal more.
Posted on Jun 25, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Thin green vertical lines
if its only one channel its your cable service, if its constant try unpluging your tv from the wall for 30 seconds to reset it, also try reconnecting any AV cables for the source you are using, If you are using a Coaxial cable unscrew it and check to see the copper needle is not bent or damaged.
Dec 19, 2013 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Green and purple horizontal lines
You will most likely need what is called a scan converter/scaler. It will convert your source signal to the desired signal for you. You can find these online.
Nov 21, 2012 | Mitsubishi Televison & Video
I have a sony 60 in rear proj. lcd that has no red in the picture other than faint red vertical lines all the way across about an inch apart. any ideas ?
It sounds like you do not have the red component cable firmly inserted. I had this problem on my first HD TV, when the green component cable popped out when I moved the TV back in place, and the picture was desaturated of any green, causing my wife to remark, "That sure doesn't look like HD..." I reinserted the green component cable, and the picture was excellent. Check those component cables.
Feb 06, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Picture junping
You possibly have a cracked solder joint in the vertical circuit, possible the vertical Ic itself. You'll have to remove the board and look carefully at the soldered connection of the vertical circuit and see if any are ring cracked. Some soldering should fix the problem. If you let the problem go too long the heat these cracks generate will eventaully short the vertical Ic..
Bill
Dec 04, 2008 | Emerson EWF2004 20" TV
Westinghouse LTV-27w7 HD TV, two yrs old, blueish square flashing on & off, no picture.
if you have warranty work they will direct you to the service center you will need, I do not know of any bb that service tv's.
May 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Mitsubishi WD62530 62 in. HDTV LCD displaying blue vertical lines
i just got the same tv today and the same thing happend to me but it happend with the satellite input and i did not have the blue vertical lines i just had a black screen and sound. i unplugged the hdmi cable that carried the signal to the tv and plugged it back in and i had a picture. hope this helps
Dec 17, 2006 | Mitsubishi WD62527 62 in. LCD HDTV
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
139 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
