Question about Hobart H600 Stand Mixer
Oil leaking from shaft after wew moved it
Oil leaking from shaft after we moved it , it sat for about ayear ?
  • 54 Answers
Oil seal around the shaft probably dried up. Before replacing, try penetrating oil at seal, wait a day; if no better, replace seal.
Posted on Jun 25, 2009
Beater hard to remove...oil leaking out of the place where you insert the beater
The agitater shaft that the beater attaches to is bent and needs to be replaced. It's easy to do . You should replace the shaft , pin, and seal above it. You may also want to replace the part the shaft mount through, to stop oil leak. You can google the model number and find a parts breakdown for the part numbers .
Aug 26, 2011 | KitchenAid 32685 Mixer
I was mixing a cheesecake with my stand mixer when I began to notice that the color of the cheesecake batter had changed. It looks like a metallic color. What happened
Perhaps oil is leaking from the gear head?? Check the shaft and see if there is oil or grease leaking from where that shaft enters the machine.
Apr 03, 2010 | KitchenAid Food Mixers
I have oil leaking from the beater shaft. a lot
TRY REPLACING GREASE IN GEARBOX AND MAKE SURE YOUR FELT COVER IS IN PLACE (AND CLEAN) THAT SITS UNDER GEARBOX.
**** KENWOODCHEFUSEDMIXERSANDSPARES
Jan 05, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My mixer is leaking oil. last time we made bread dough in it it sounded kind of rough. we figured wiyh the heavy load maybe that was the rteason for the noise. when we moved the mixer to clean it, there...
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
May 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
HOBART H600 Leaks oil.
There's an o-ring that goes around the attachment shaft,if you get a flashlight and look into the hole you will see a screw (left handed threads),remove screw and pull out shaft.Put the o-ring on and install the shaft and screw.
Feb 24, 2009 | Hobart H600 Stand Mixer
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid mixer is leaking from the part that spins?
I took mine apart and all the grease had settled down around the shaft in the housing due to lack of use,found no seal.Going to spread grease back up on gears,see what happens.I found this at KitcheAids web site.Good luck.
Dec 01, 2008 | Food Mixers
Oil leaked from housing
my ultra power ksm90gr 300 watt mixer leaked oil when in the upright position overnight. whats that all about?
Nov 10, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Leaking oil
thats the planetary seal thats leaking.the seal is cheap its the labor that may be costly.is it just a nuisance leak or a lot?you dont want any oil to get in your mix.
Aug 16, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Hobart H600 Stand Mixer Logo
337 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
