Question about Lexmark X5470 All-In-One InkJet Printer
I cant receive fax. it has some in the memory.
I cant receive fax. it has some in the memory. how do i get rid of the old ones ?
    Sergeant:
  • 199 Answers
If there are a message like empty cartriage or low cartridge that means
the printer want new cartridge for print fax, when it print another document and also print reports without trouble.
Posted on Jun 25, 2009
Is it possible to reprint a fax I received on my Pixma MX310
Hi! have you tried this:
http://www.fixya.com/support/t6754616-canon_pima_mx340_printer_fax_machine
Nov 29, 2012 | Canon PIXMA MX310 All-In-One Printer
How do I get the 'autoprint off' to go back to autoprint...cant find it in the book...thanks
Receiving to Memory Temporarily
You can enable memory receiving feature temporarily.
1 Press [ON/OFF] to select .
z The fax starts receiving documents in memory.
z To cancel, press [ON/OFF] again.
Jan 30, 2011 | Canon FAX-JX200
Message saying "received in memory", what does it mean and how do I get rid of it?
It means there are pending documents in the memory of the printer awaiting to be printed. This documents could be a received fax documents or a documents failed to send.
Just press the menu button to enter fax setting: under it the appears "receive mode set"...... use the right arrow button to go to "memory referrence" then click OK button.
Use again the arrow buttons to delete documents in memory.
Oct 15, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Says memory is low cant print how to fix
Do the following:
1. Make sure that the memory does not have any faxes in it waiting to be sent if so send them.
2. Make sure that the memory does not contain any received faxes still waiting to be printed if so print them.
3. Use the HP ToolboxFX Fax tab to perform fax tasks from the computer. The Fax tab contains links to the following main pages:
● Fax Tasks. Perform such tasks as sending a fax or clearing the fax memory.
Fax Data Properties. Manage the space used to store faxes on a computer. These settings apply only if you have chosen to send or receive faxes remotely from the computer.
Enhanced I/O
The enhanced I/O (EIO) feature allows all-in-one memory to be used for storing data received from the
host computer. When EIO is enabled, more data can be sent to the all-in-one in shorter amounts of time
so that the user can return to the software program more quickly. The
EIO feature has the followingoptions:
Auto. The all-in-one uses EIO memory allocation to increase the speed of data transfer from the host computer to the all-in-one, if necessary. The default setting is Auto.
Off. The minimum amount of all-in-one memory is used to store data that is sent from the host computer.
Page Protect. The formatter creates the entire page image in page-buffer memory before physically moving the media through the all-in-one. This process ensures that the entire page is printed.
Oct 21, 2009 | HP LaserJet 3055 All-In-One Printer
The screen keeps on showing " memory full".
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 21, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Want to make sure memory is 100% cleared/erased before getting rid of it.
what you need to do is a shipment set . that will erase all data completely . if it makes you happy do it twice.
Nov 05, 2008 | Panasonic PANAFAX UF-6000 Fax
Erased files
the problem is the fax that are stored in memory you will lose anyway.
you will need to do the following to get rid of your error:
DATA REGISTRATION button,
and # button, on the operation panel
go down to number 8
then scroll round to ALL
and then restart the machine and the fault should go.
Hope this helps
Oct 23, 2008 | Canon FAX-L800 Plain Paper Laser
Canon MX 300
I cant send Fax. I also receive a message ''waiting for report''and"memory receive mode". Please Help
Sep 17, 2008 | Canon MX300 Office All-In-One Printer
Fax Memory full
How i can delete fax HP LaserJet 3050 memory?
Feb 07, 2008 | HP LaserJet 3050 All-In-One Printer
Printing same page
try this make sure that receive reduction is switched on. You could load the paper tray up and just let it print as may have been a communication problem from RTI memory. Being Richo machine you should be able to reset the memory but this will get rid of all your stored numbers. But it will reset the machine so if you have a corrupted memory issue this will get rid of it.
Hope this helps you
Thanks J
Sep 11, 2007 | Ricoh 3310LE Plain Paper Laser Fax
Lexmark X5470 All-In-One InkJet Printer Logo
120 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
