Question about HP LaserJet 1320 Printer
HP LaserJet 1320
The printer wont pick up the paper and but there a small grinding noise coming from the bottom right handside of the printer.
Any idea?
  • Quilt Club Nov 07, 2008
    We have the same problem.  There is a little arm or "finger" just to the right of the pick up roller that seems to be very loose.  This is also the area where the noise is coming from.  What is this called or what is it's function?  I can't find any info about it.  The printer will not pick up paper.  If I put paper in the manual tray it pulls the paper through (back and forth) but nothing is printed on it.  The paper error light turns amber and it says it has a paper error.  There isn't any paper caught in the printer.
Do not clean rollers with alcohol only with water and magic rag!!!
Because the alcohol is to strong for rubber and it might destroy layer on roller
Posted on Dec 04, 2007
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
1=- try cleaning the rollers with alcohol and clean rag to see if it helps if it feeds at least one page,change tires.
if it makes noise and does not try to pick up paper it may be a gear is stripped
Posted on Nov 08, 2007
  • 57 Answers
Hi all of you
your sound as you have mechanical problem in the clutch gear , there is spring sandwitch between two gears , it may get out of it is place , try to fix it properly so as the clutch be functional,
I think these need some experience,
hope this helpfull
Posted on Nov 08, 2008
download the service manual..... 1320
Oct 24, 2015 | HP LaserJet 1320 Printer
Paper Feed problem
I think its logic board related problem.
have a technician look onto it...
Nov 08, 2013 | HP LaserJet 1320 Printer
My hp laserjet 1320 takes in more than one paper while printing, which get stuck.
Cleaning the pickup roller will only temporarily delay problem. The pickup roller and separation pad needs to be replaced to correct the multiple paper pickup problem. The roller and separation pad is easy to replace. These parts come in a kit caller RK-1320 the parts kit is available here:
Mar 28, 2013 | HP LaserJet 1320 Printer
Tis can't pickup the paper and its making noise
If your printer can not pick up the paper then you need to change the pickup roller and separation pad. You need to get the preventative maintenance kit RK-1320, this has the roller, pad and transfer roller. It is available:
Oct 16, 2012 | HP LaserJet 1320 Printer
1320 HP Laserjet Still Won't Pick Up Paper
Please check limiters paper in tray 2 to be on A4, letter, depending on paper format. Otherwise you have problems with taking the sheet from tray 2.
Oct 09, 2009 | HP LaserJet 1320 Printer
HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Hp 1320
I want the software of laser jet 1320 printer
May 19, 2008 | HP LaserJet 1320 Printer
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at .
Feb 15, 2008 | HP LaserJet 1320 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
I hope this helps, if so please rate my solution.
Dec 05, 2007 | HP LaserJet 1320 Printer
Paper jam
Look at this link for information on paper jams on the HP LJ 1320:
Here is a general link to HP's support site for paper feeding issues:
Nov 08, 2007 | HP LaserJet 1320n Printer
HP LaserJet 1320 Printer Logo
703 people viewed this question
Ben Johnson
