Fuse blown furnace runs fine but when you turn on a/c fuse blows. I tried to by pass therm but nothing changes if i go out side to unit and push in switch unit starts and runs with thermo on fan run
  • 3 Answers
Could have bad compressor
Posted on Jun 25, 2009
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Coleman Presidential Furnace 6806A842 heat switch pops then cool air
Make sure all vents are open and filters are clean. Likely an air flow issue but possibly, though unlikely, both switches are bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 05, 2017 | Heating & Cooling
Furnace blower runs continuously but no heat
sounds like the furnace control (low voltage) circuit is open, or in other words you either have a fuse blown or a limit switch that needs to be reset. Most newer furnaces have a small knife like fuse, usually 3 or 5 amp located directly on the circuit board. Limit switches that have a manual reset are usually located in the fire box just above the burner. There may even be a limit switch located on the blower assembly. If you fuse was blown, you may need to find out what caused the short in the circuit or it will do it again. If the limit switch was tripped, you need to turn the furnace back on and watch the flame to see if there is "roll out". It it continues to trip or blow fuses you need to have the unit serviced.
Apr 10, 2011 | Dayton Gas Furnace Heater
Ruud IFC Furnace Blower comes on and stays running, never lites
Check on the circuit board for an automotive type fuse that is probably blown. These fuses blow because of a short in the control wiring. If the fuse is blown a lot of furnaces run the fan all the time as a diagnostic. You will have to find the short or it will just blow again.
Oct 04, 2009 | Heating & Cooling
My electric furnace/heat pump runs even when the therm is off.
electric furnaces turn on the heat in stages so you dont get a major surge. the fan and the "first stage of heat" are on the same switch. that switch is stuck closed, so that it always has power going thru it. it needs to be replaced
Aug 27, 2009 | Heating & Cooling
NO POWER TO DOWNSTAIRS FURNACE NO FAN NO AC ??
what brand? most likely fuse is blown on furnace control board if there is no fuse then transformer could be blown sounds like a short in system look for bare wires at ac unit small wire outside especially if your have dogs around ac unit
Jun 24, 2009 | Heating & Cooling
Carrier Central Air Conditioner
If nothing is happening could be thermostat control wires cut? try using a jumper wire @ the furnace their will be a board with the letters R G W Y B try to jumper R to G the fan should come on. if not its in the controls of the furnace if fan comes on replace the thermostat. don't short the wires you will blow that small fuse. T
Jun 16, 2009 | Carrier 38CKC042 Air Conditioner
Fan and compressor will not run
Try replacing the fuses for the condensor.
Apr 24, 2009 | Goodman CKL36AR36 Air Conditioner
Air conditioner/furnace squirrel cage fan remains running when th
Ensure you don't have a short in your therm wires. Disconnect them, if the furnace continues to run, you have a lockout problem at your furnace. When the motor on the fan fails, it wont run. Check for led codes on the control board. If you don't have led codes, turn off the power to the furnace at the breaker, and watch the unit. If nothing happens, connect the thermostat. If nothing happens still call for heat. Let the therm run through it's cycle, and if the bower runs continuous again, let me know we can walk through that situation.
Dec 05, 2008 | Ruud Central System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
