I have one LX 300 + dot matrix printer. print out in dos mode draft ok but sans serif font make print double character.
1,041 people viewed this problem
This solution has been voted best by the Fixya Commnunity
Please change the setting print direction from bidirection to unidirection.
How to check print head Epson lX300+
I tried replacing the motors and the issue persisted, so I have to assume it was a board issue. Switching the printing to unidirectional as suggested by Albert124 took care of issue for us, as we were not concerned about printing speed, since our equipment runs at 300 baud.
The problem is with printer's carriage unit, just replace and check it.
bye
Language as chainged
Hi, i'm making an application and i have e problem when it prints in the EPSON LX-810 printer (a dot matrix old...
I am developing a program which will use a dot-matrix printer to print labes. I have done it but about in every 3...
Hello TeamSybase How do I increase the speed of printing of a Report generated by a Power Builder Application and...
epson LX300+, in off line test first Roaman charcter set prints perfect as good as new printer. After that Sans serif,...
got 2 units Epson printer (1 is Epson LX-300+II and Epson LQ-300+). When print the same document, the font print out...
I'm using am Epson LX300+ with CystalReports reports. In my aplication, preview on page Fanfolder305x210...
everything is perfect may be confused whether head's problem,if yes how it will be changed?
i have an AOC Monitor model 4vn, my problem is that bothsides of the monitor is bending, manually adjustments inside...
qlenfg We use the LX300, LX300+ and LX300+ II printers with some of the equipment we sell and service. I thought I had seen every problem on these models until I had a unit printing double on the NLQ fonts.
Doing a test print, the characters look fine for the first couple of lines, then the letters start slurring. It appears the two passes required for the NLQ fonts are not aligned -- the alignment gets gradually worse and worse with each line printed.
I have cleaned and lubricated the guide rod the print head travels on, which is usually an issue with the units we see, but the issue remains. I'm guessing the issue is either with the main board, the motor that rolls the platten or the motor that moves the head.
I have a spare chassis with working motors I will try first. Unfortunately, I do not have any spare main boards.
Feb 06, 2008
knightfeith i also have the same problem! please help me...
Dec 10, 2007
Lindi Steyl I have the same problem, the printout letters appear double!
Nov 29, 2007
