Excel 2007 I use office 2007 , if i make formulas in excel and I want to hide them (so no one can see the equation in the formula bar) just allow users to enter data and just see the result only , so that no one see the equation and change it . Please help me and tell how to make this in details Thank you in advance
  • sherin_fahad Jun 27, 2009
    thank you so much sir
    best regards
    Scholar:
  • 78 Answers
  1. Select all cells (either press Ctrl+A or click on the small upper left square on the edge of the worksheet)
  2. In the menu bar, go to Format - Cells
  3. In the popup menu that opens, click on the Protection tab (it should be the last one on the menu)
  4. Deselect the small box tagged Locked
  5. Click on OK. Now all your cells can be overwritten, regardless the protection status of the worksheet.
  6. Select only the cells containing formulas that you want to hide (If you need to perform multiple selection, you can press and hold down the Ctrl key, while clicking on each cell you want to select)
  7. In the menu bar, go to Format - Cells
  8. In the popup menu that opens, click on the Protection tab
  9. Tick the small box tagged Hidden and the Locked box as well. If you don’t tick the Locked box, other users of your worksheet would be able to overwrite the formula cells, without even knowing that they contain formulas (as they become invisible following this operation).
  10. Click on OK
  11. In the menu bar, go to Tools - Protection - Protect Sheet
  12. If you want, you can input a password for unlocking the worksheet. This will prevent others from unlocking it. If you don’t want to do that, leave the password field blank and press OK.
  13. Now click on one of your cells containing formulas and look at the formula bar. It should be empty, although the formula is still there. The cell would remain locked, but it would be automatically updated when changing the content of its precedents relating to the contained formula.
Posted on Jun 27, 2009
    Sergeant:
    Novelist:
  • 167 Answers
Now you need to lock the formulas in excel sheet. So click the selection lock option. After clicking the selection lock option, you can see a popup dialog box. Pass the ok button. Then click the protect sheet and give a password with check the 1st two box. Click the ok. You can again see a popup message for confirming the password. After confirming the password. Now, you successfully look the excel sheet.
Source: Technologish
Posted on May 02, 2018
Whenever I work in excel 2007 file.It show compatibility mode n top and any formula are not working properly in file.
When you open Office 2003 files with Office 2007, it works in compatibility mode, so that if you open the files in earlier version (i.e. Office 2003 etc) there would be no issues (reverse compatibility with earlier versions.
Regarding formulas, rest assure that compatibility mode does NOT affect the calculations at all. All formulas are reverse compatible.
So, it is recommended that you may save the file in Word/ Office2007 format. Do review your formulas for errors (if any).
CreativeTECH
May 16, 2011 | Computers & Internet
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
What is the function of Microsoft excel?
Ok - if your question is "What is Excel" - then the answer is that it is a spreadsheet program that allows you the ability to compute data (usually numbers) for example, pulling together a list of hours worked by employees and adding them up automatically. It also can be used to develop sophisticated computational models and I have used it to develop professional services proposal sizing tools using formulas and functions ... which is a good segwey into my other answer.
If your question is "what is a function or formula in Excel" - then the answer is a function or formula in Excel is a collection of mathematical, text, statistical, etc. preprogrammed tools that allows you to manipulate the data you have in your spreadsheet e.g. a SUM() function that adds a series of numbers, and AVERAGE() funtion that computes the average of a series of numbers, etc.
Hope that helps!
Rgds
David
Oct 01, 2010 | Microsoft Office Excel 2007 Upgrade:...
Ms-office
Subtraction can be done in two ways in Office using the following formulas in the formula (fx) bar:
  1. =A1-A2
  2. =SUM(A1,-A2)
The above formulas refer to cell reference A2 subtracted from A1. As usual, you can use number values instead of cell references.
The SUM formula subtracts by changing the sign of the reference. Remember the sign rules, and thus - -x is in effect +x.
Jul 08, 2009 | Microsoft Office Excel 2003 for PC
Countifs
The formula in both versions is the same:
=countif(range,value)
i.e. The below formula will increase its count by one if any of the 18 cells it's checking are equal to 1.
=countif(A1:B9,1)
Jan 21, 2009 | Microsoft Office Excel 2003 for PC
Excel
Step1. Start Microsoft Excelmag-glass_10x10.gif and open the file you want to change. Step2. Double-click on the cell where you want the total to appear. Step3. Press the = key on the keyboard. This tells Excel that you are entering a formula into the cell. Step4. Enter the formula, then press Enter. Follow the steps below for an example. Step5. Enter an opening parenthesis character: (. Step6. Enter a cell name. For example: =(E2. Step7. Press the + key. Step8. Enter another cell name and a closing parenthesis character: ). For example: =(E2+E3). Step9. Enter a minus sign and a third cell name. For example: =(E2+E3)-E4. Step10. Press the Enter key to accept the formula. The cell will display the sum of the first two cells minus the third cell. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Tips & Warnings
  • Formulas are just equations. Instead of adding or subtracting numbers you are adding and subtracting the contents of a cell.
  • Excel includes a number of predefined functions to use as well. You can combine the predefined functions into your own formula. (See "How to Use Provided Excel Formulas.")
I hope it helps!!!
Dec 03, 2008 | Microsoft Office Professional 2007 Full...
Formula for calculating the days beween months
for example, cell A1 has date (01-01-2008) and cell A2 has current date (08-24-2008) and cell A3 shows total days, is that you want to know? if yes, apply formula as under...
cell A3......(properties set as General to show digits)................ =SUM(A2-A1)
Aug 25, 2008 | Microsoft Office Professional 2007:...
Excel Coordinates don't show up in Formula Bar
Heyo. I have had this problem before too. This procedure prevents the cells that contain the formula from being edited.
  1. Select the range of cells whose formulas you want to hide. You can also select the entire sheet.
  2. On the Format menu, click Cells, and then click the Protection tab.
  3. Select the Hidden check box.
  4. Click OK.
  5. On the Tools menu, point to Protection, and then click Protect Sheet.
  6. Make sure the Protect worksheet and contents of locked cells check box is selected.
Good Luck!
Wayne
Dec 28, 2007 | Computers & Internet
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
