Question about HP Compaq Business nx7010 Notebook
Sdhc driver update compaq nx 7010
Ist es möglich sdhc Speicherkarten zu lesen? bisher gehen nur sd und mmc.
SOURCE: 2GB SD card no recognized
Thanks.
I have only one card reader. Will see if I can find a way to connect my GPS with the SD card in it to the PC.
Otherwise I guess I need to .. buy a new card.
What do you mean by formatting the SD card. I copy a file on it from Windows explorer (copy/paste) without doing anything to the card? If I buy a new card, should I format it first? How?
Since the system does not recognize the card I cannot do anything to it.
Thanks!
Posted on Mar 13, 2008
1234s282
  • 144 Answers
SOURCE: SD vs SDHC on the HP mini 1000
Yes , SDHC is the name given to SD cards that can hold more than 2gb of data like 4gb or 8gb. they use the same slot as SD cards
Posted on Jan 05, 2009
jennifer720
  • 830 Answers
SOURCE: My compaq NX 7010 laptop will not boot lights just
Hello and thank you for using Fixya's services.
I have a couple of questions and some troubleshooting tips for you:
Questions: Is the splash screen coming on at all? Any picture or text right when you boot up? What Windows are you running (Windows XP or Vista)? Are there any lights on when you boot up or beeps? If so how many beeps do you hear?
First troubleshooting: If it boots up and is at least showing the splash screen (Compaq splash screen or text) then it would be that the operating system is corrupt. This can be caused by several things included viruses, power surges or hardware failure.
The solution for this would be to take the hard drive out and slave it to another working desktop computer to retrieve your data. The attach the hard drive back on and reformat it (I can add specifics to doing this once I know the operating system).
Second troubleshooting: If you hear the operating system chime but do not see a picture and all the lights are on, then this would indicate that the back light on the screen is out. You can test this simply by hooking the laptop up to a monitor and see if you get a picture. If the computer screen shows on the monitor, then your back-light is out. If it doesn't show up then your video graphics card is out.
If the back light is out, it is easier to order a new screen (new or used) from eBay and just switch out (simple process and you can find a replacement for under 50 dollars on eBay). If it is the video graphics card, then you can also purchase one from eBay and switch out (a little tougher because you have to take the top of the laptop off). You can get assistance with this from the manufacturers website and pull specs for free.
Third troubleshooting: If you do not hear any beeps and the above solutions did not work. Then your motherboard has failed. This can be caused by surges or dust. You can purchase a replacement from eBay for a fraction of the cost and replace (this is tough and I am not sure if they have specs for this). You can do it yourself, just be sure and put everything back together as it was.
Fourth troubleshooting: To test the battery, take the battery out of the laptop and turn on with just the adaptor. If it boots, then the battery will need to be replaced. There is no way of testing the power adaptor but 85% of the time, this is the problem. Even if lights come on, the adaptor sometimes gets so overheated that it silently goes out but gives just enough power to make the lights come on. The power adaptor can be found on eBay for under 20 dollars and is cheap enough to replace (first) to make sure that is not the problem. The battery can also be found on eBay for under 60 dollars.
Please let me know if you have any questions and I will be glad to assist.
Posted on Nov 03, 2009
HP Xpert
  • 112 Answers
SOURCE: sd.ms pro.mmc.sm.xd drivers for HP Compaq laptop
Download correct driver from www.hp.com/support and install
Posted on Jan 19, 2010
WAS IST HPSU-0004 WIE KANN ICH ES INSTALLIEREN
Hi!
Erstens verzeih mir bitte wegen Schreibfehler. Meine Muttersprache ist nicht Deutsch.
Jetzt zur loesung:
1. Auf der support-seite von HP suche und lade herunter die (sehr grosse) Datei welche die FULL drivers und applications fuer dein Drucker beinhaltet;
2. Starte die gerade heruntergeladene Datei bis zum Punkt wo es anbietet die software zu installieren;
3. Click NICHT auf "Install", sonder verlasse den Installer (z.B cancel). Am diesem zeitpunkt haben wir auf die festplatte alle spaeter notwendige Dateien;
4. Jetzt finde den Ordner wo alle diese Dateien gespeichert wurden. In diesem Ordner soll der Ordner "setup\hpupdate" sein. (der Ordner musste in TMP oder TEMP sein - am besten verwende die option SUCHEN;
5. Nur nachdem du den Ordner gefunden hast koennen wir fortsetzen:
6. In Windows Systemsteuerung, programme entfernen, werden wir das programm"HP Update" entfernen. Kann sein dass mache Fehlermeldungen dabei entstehen, aber das ist normal unter diese Umstaenden
7. Jetzt gehen wir zurueck zu dem Ordner den wir bei Schritt 4 gefunden haben. (setup\hpupdate), und doppleclick die einzige *.msi Datei die es dort gibt. Dadurch wird die HP Update Utility neu und richtig installiert;
8. Wenn die Installation (Schritt 7 ) vollendet ist, kann die HP-Update utility ausgefuhrt sein, um updates fuer alle Deine HP anwendungen zu erhalten.
Hoffe es war hilfreich
Beste Gruesse!
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Tip
Fixya Hilfe in Deutsch
Brauchen Sie Hilfe von den Experten auf Fixya, aber Sie müssen auf Ihre Frage auf Deutsch stellen? Hier ist eine einfache Möglichkeit, Ihre Antwort zu bekommen!
Wussten Sie, dass es freie übersetzung von Google zur Verfügung? Ja das ist richtig! Jetzt können Sie Ihre Frage auf Deutsch zu schreiben und übersetzen sie ins Englische! Dieser Tipp ist geschrieben mit dem kostenlosen Google-übersetzung. Es ist nicht perfekt, aber es wird funktionieren gut genug, damit jemand Ihre technischen Probleme zu beantworten.
Hier ist der Link: Google Kostenloser Online-übersetzer
Go to this Google-Website, geben Sie Ihre Frage in deutscher Sprache und es wird automatisch übersetzen für Sie. Die nur auswählen und kopieren Sie Ihre übersetzten Text und schicken Sie ihn in Ihrer Frage FixYa Feld auf der Seite!
Dies wird dazu beitragen die FixYa Experten helfen Ihnen gerne!
Dann, wenn Sie ihre Antworten zu erhalten, kopieren Sie einfach den Text, und nehmen Sie an die Google Translator Seite und biegen Sie ihr Englisch in Deutsch!
Willkommen bei FixYa und wir hoffen, wir können Ihnen helfen!
on Dec 21, 2009 | Computers & Internet
Bei unserer Canon sehen wir kein Bild mehr auf dem Monitor. Man hat auch kein Foto wenn man abdrückt.
Ich hoffe, dass Sie mit den folgenden, wie ich nicht Deutsch sprechen, und ich bin mit Google übersetzer. Ein stecken Auslöser ist ein weiterer häufiger Fehler-Modus für Digitalkameras. Die Symptome einer stecken oder "klebrige" Auslöser sind sehr ähnlich zu CCD-Bildsensor Scheitern. Die Kamera kann Bilder aufnehmen schwarz (für Verschlusszeit fest geschlossen), oder die Bilder können sehr hell und überbelichtet, besonders wenn im Freien getragen (für Verschlusszeit fest offen).
Um eine Verschlusszeit fest zu bestätigen, legen Sie die Kamera in einem anderen Modus als "Auto", und der Blitz ausgeschaltet (Sie wollen nicht blind sich für den nächsten Schritt).Zunächst blicken die Linse und ein Bild. Sie sollten ein kleines Flackern in der Mitte der Linse sehen, wie der Verschluss öffnet und schließt. Wenn keine Bewegung zu sehen ist, dann haben Sie wahrscheinlich ein Auslöser stecken. Wenn ja, lesen Sie bitte diesen Link für weitere Informationen und ein einfaches Update, das helfen kann.
Mar 19, 2010 | Canon PowerShot A620 Digital Camera
Betrifft: Silva-Schneider SAT COMBI RECEIVER Modell Gran Prix STR 755HDD # 070907424 made in Germany Das Gerät folgt seit kurzem der Fernbedienung nur in sehr eingeschränktem Maß; es...
Dear Sir,
I think I have the same problem.
Can you share with me, what was the solution, if there was anything.
Thank you
Zsolt Bozsik
bozsikzs@gmail.com
Feb 19, 2010 | Televison & Video
Hallo, meine Camera wie oben funktioniert nur noch wenn keine Speicher- karte im Gerät ist. Mit Speicherkarte ist kein Strom vorhanden. Wo ist hier das Problem. Habe kein Geld für teure...
Ich bitte um Entschuldigung, aber ich bin mit Google übersetzer. Bitte schauen Sie in Ihrer Kamera CF-Karten-Slot. Ich vermute, dass Sie eine gebogene Nadel in es haben kann. Wenn ja, entfernen Sie die Batterien und Karte. Verwenden Sie einen kleinen / dünnen Juwelier flachen Schraubenzieher, bis die Nadel verbiegen wieder so nah wie möglich. Eine preiswerte Juwelier Schraubenzieher funktioniert problemlos. Ein weiteres Tool, benutze ich manchmal ist ein steifer Draht mit einem gebogenen Haken am Ende. Dies trägt dazu bei sehr flachen Pins erhalten begonnen. Nehmen Sie sich Zeit und verbrauchen viel Geduld (machen Sie eine Pause dazwischen, wenn nötig). Macht einfach weiter es nach oben und gerader einer "kleinen Menge zu einer Zeit". Was immer Sie tun, versuchen Sie nicht, um es mit einem Tastendruck entspannen, werden Sie nicht in der Lage, es zu tun.
Es muss nicht perfekt sein, nur so nah wie man es bekommen kann. Wenn es das Beste, was Sie es bekommen können, nehmen Sie Ihre Flash-Karte und "langsam" einfügen. Die Karte selbst ist fein-align des Stiftes. Entfernen Sie die Karte, und stellen Sie sicher, dass die PIN noch gerade ist. Wenn ja, setzen Sie die Karte und versuchen, die Kamera.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
HP Compaq Business nx7010 Notebook Logo
999 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
