Question about HP Deskjet 870cse Printer
HP DESKJET 870CSE is not catching the paper properly. Blinking light above power buttom must be hit to get printed copies. It print "Hewlett Packard Deskjet 870C Profesional Series "The power of color: The ultimate way to communicate. What must I do for the printer to run properly? How can it stop printing what I'm not asking for? It will not print properly. Need emergency help!!!
    Sergeant:
  • 199 Answers
Clean the paper small pick up rubber roller (located inside in the paper tray) with waterized cloth.
Posted on Jun 25, 2009
I need a print copy of a user manual
[PDF]HP Deskjet 2540 All-in-One series
www.hp.com/ctg/Manual/c03847745.pdf
Hewlett?PackardAdvanced printer management tools (for networked printers) . .... Learn how to useyour HP Deskjet 2540 series. ?. Printer parts on page 4. ? ... Paper-width guide for the input tray. 7 ... Press the Wireless button and the Start Copy Black button from theprinter .... One corresponding cartridge is low on ink and will need.
[PDF]HP ENVY 4500 e-All-in-One series
h10032.www1.hp.com/ctg/Manual/c03784120
Hewlett?PackardThe printer is printing, scanning, copying, or is on and ready to print. ENWW .... You do not need to manually reload the paper or make any operations. ENWW.
[PDF]USER'S GUIDE - Brother
Dec 29, 2015 | Office Equipment & Supplies
Excel sheet not print for hp laserjet p1007
please do the following check if the printer is on and is blinking green will printing if its blinking red then it means there is a problem,if its green and its not printing the following might be the problem
  • your print server is slow Add more RAM to increase its printing speed
  • your print drivers are not well reinstall them
if its blinking red then check the following
  • paper jam-paper stuck in the computer
  • print ctaridge not placed properly
Jan 19, 2015 | HP Hewlett Packard LaserJet P1005 Printer
Hp C309n blinking power light
The blinking light indicates there is a malfunction; such as paper jam, cartridge missing or ink cartridge caddy has a problem (ink on bottom, or dryed up, etc; caddy can be pulled out and cleaned), or something you were going to print was not printed due to low on ink, etc. It may show a number that you could contact H/P support, give them model of printer and the error number and they may be able to assist. Actually, blinking light could be a host of problems. Take cartridges out and carefully clean the brass contacts and also on the printer head, clean that too. Edwin, USN-Ret.
Apr 08, 2014 | HEWLETT-PACKARD Photosmart Premium C309n...
Hp color laser jet cp4025 blinking yellow light
Yellow toner is getting low, or check to make sure your print driver is set correctly for this printer.
Mar 22, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
HP 870Cse feeder/roller is dead
Take a very small amount of Goo Gone on a paper towel and roll it over the rollers. You can press and hold the top button to get the rollers moving. This will revitalize the rubber rollers. My printer is over ten years old and I do this about every two years and never get a misfeed.
Dec 08, 2009 | HP Deskjet 870cse Printer
Seems like the rubber feeder wheels won't pick-up the paper to feed... what can I do to get my HP 870cse to feed?
Usually that is caused by foreign object restricting the operation.
take the feeding tray out and open the top and examine it for foreign objects. It may need a little cleaning.
Nov 05, 2009 | HP Deskjet 870cse Printer
Compatibles wont work
Try this:
The HP all-in-one product will print black copies using both the color and black cartridges to create composite black in Normal and Best modes. This is necessary to create the correct grayscale shades.
  1. The color cartridge may be out of one color of ink. Perform the steps in the 'Colors are not correct' section above to verify that the ink cartridges are not low on ink.
  2. Verify that the correct paper type is selected in the Paper Type setting.
  3. Some photo paper has different chemical characteristics than Hewlett-Packard paper. The HP all-in-one is designed for use with HP Premium and Premium Plus Photo Paper. The photo paper, paper-type setting should be used with HP Photo Paper. For other paper brands, it may be necessary to use the plain paper or premium Inkjet paper, paper-type settings.
OR: The ink cartage you have may be defective if is a refilled or recharged cartage.
Jun 17, 2009 | HP DeskJet F380 All-In-One Printer
The yellow light blinks and it won't print
I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
Jan 21, 2009 | HP Deskjet 870cse Printer
HP Deskjet 870cse Printer Logo
150 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
