Question about Kenmore 24 in. 15079 Built-in Dishwasher
Dish Washer retains the water without draining....
I have a Kenmore Dishwasher Model 665 about 8 years old. After the wash is done, the water still remains at the bottom of the machine. It goes thru' the whole cycle without shwoing any problems, but at the end water remains. Cleaning is not neceeasrily great. I tried just draining the water but the water does not drain.
Is ther an issue with the drain valve?? Do I need to replace it and if so how? What m,ight be the cost I am looking at? Is it worth it it repair it than replace??
Please advise....!
Thanks..... Shekh
  • cellomaa Jun 25, 2009
    Thanks for the reply
    Do I need to replace the drain Valve or the Drain Pump....? Some body mentioned replacement of the Valve.... So wondering? I hope they are not very expensine..!
    Thanks again....
    Sergeant:
  • 212 Answers
The drain pump is fairly easy to replace. it locks into place beside the sump and motor. push tab in and rotate pump to pull out. you will lose water so have a towel handy. inspect drain hose for restrictions or kinks.
Posted on Jun 25, 2009
Model 665.13929kq11. Why isn't it draining completely?
Dishwasher is draining slowly , and not completely ... - iFixit
https://www.ifixit.com/.../Dishwasher+is+draining+slowly+,+and+no...
iFixitJun 26, 2014 - I have a kenmore dishwasher (about three years old) ! ... with a solid plug in the drain tube for situations where a dishwasher isn't connected.
My Kenmore Dishwasher Won't Drain and is Leaking- How ...
? 5:35
https://www.youtube.com/watch?v=u7uaA2NZKl0
Nov 14, 2011 - Uploaded by mkbrennan13
This is a video to help someone fix their dishwasher. It's a How to fix your dishwasher that won't drain. If your dishwasher isn't draining and ...
How to fix drain problem with kenmore dish washer - YouTube
? 6:46
https://www.youtube.com/watch?v=ZMPXn6XgRkk
Aug 16, 2010 - Uploaded by itdatanow
Kenmore dishwasher would not drain. ... How to fix drainproblem with kenmore dish washer ... Is Your Dishwasher DrainInstalled Properly?
Dec 12, 2015 | Kenmore Dishwashers
No reaction when start button is pushed on Kenmore UltraWash model 665 dishwasher. The clear /drain button works. No water filling
you have a bad water valve or bad user interface that's the long control in the front of the dish washer.
Dec 17, 2010 | Kenmore Dishwashers
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
I have a kenmore 665 dishwasher where the spary arms do not spin.
  • First, check water level. Start machine, wait until the machine begins main wash. Open the door, the water level should be just below the heater element. If too low replace inlet valve.
  • If you can't hear the wash motor running or is just humming, the motor may be bad.
  • To check if the food chopper is blocked or broken;
  1. Remove lower spray arm by holding the arm and rotating the spray arm retainer.
  2. In the back of the tub, unclip or remove the screw from the upper spray arm supply tube.
  3. Rotate the lower spray arm support to the right while disconnecting the supply tube from it.
  4. Remove the four torx screws from the sump cover, remove assembly.
  5. There may be a primary filter in the left side of the sump, if so, remove the torx screw and the filter.
  6. On the right side there is the chopper assembly cover. Remove the torx screw and cover to expose the chopper.
Hope everything goes well for you,
Regards
Richard
Feb 02, 2009 | Dishwashers
My dish washer does not drian completly
the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
m
Oct 27, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 15079 Built-in Dishwasher Logo
589 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
