Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
I noticed last night when I went to turn my pump on that it would not power on at all. I have primed it, unplugged it and reset the breaker and still nothing. This is my 2nd summer with this and noticed that it runs kinda loud. Any other suggestions?
I had the same problem today. I unplugged the machine and then unscrewed the four screws on theplastic plate where the hose attaches to the motor housing. Under the plate I found a little fan
type thing that I manually cranked around a couple of times. I put everything back together, primed the hoses and turned it on and it worked. It seems that little fan must stick. Don't know if it
will continue running, but its working now as I type this. I'm no pool pump tech, but it worked.
Lisa T
Posted on Jun 27, 2009
Why isn't jet pump pumping?
Your suction line has an air leak, hence no suction , no prime. All fittings have to be perfectly tight and leakfree on intake side.
Oct 18, 2015 | Jet Plumbing
Codes sy ce refrigerator display
Good Afternoon Johnny, thank you for your inquiry! Error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the unit. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Jul 27, 2013 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
My hot tub has been running perfectly until a few nights ago when the GFCI breaker tripped and now it wont reset
Either you have a ground fault or the GFCI is toasted. Turn off the power to the GFCI, open the box the GFCI is in and disconnect the output wires, close up the box, re-energize, and try to reset it again. This will tell you which problem you have.
Jun 04, 2012 | Cutler Hammer CH250 2 pole 50 amp
We lost power several times last night during hurricane Irene. The power has been on for several hours now and I noticed the freezer LED display is reading "88" and the fridge display is...
If you don't want to roll the unit out, then turn the circuit breaker off in the panel. The quick disconnect does not reset the electronics for the compressor. Try that and see what happens.
Aug 28, 2011 | Microwave Ovens
I blew a fuse last night and had to reset the breaker....I went to dry clothes this morning and the dryer is dead, wont come back on after being plugged and unplugged. I reset the circuit breaker too and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our Wii was plugged in last night, this morning there is no power, we have unplugged everything and replugged back in, still no power. What do I do?
How long did you unplug the Wii from the power supply? As to reset the power adapter it needs to be unplugged from the power for a full 2 minutes before plugging it back in and trying to power up the Wii. (This resets the circuit breaker in the Wii power supply)
Cheers
Apr 05, 2010 | Nintendo Wii Console
Power went out in house last night. Now the fan
First check where the fan draws power from.
A light switch? Is it on?
Blown fuse, tripped breaker?
Oct 30, 2009 | Hunter Designer's Choice 5-Switchblades Lg...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
392 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
