Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Freezer leaking I have a frigidaire side by side. The freezer side leaks water, it freezes in the bottom of it and than leaks out the front and side of the freezer. It still makes ice.
  • 351 Answers
Your drain is probably plugged with something take tha back off of the freezer and find the drain .... let me know what you find out...
Posted on Jun 25, 2009
FRS26KF6EMB
The water valve sounds like it may be leaking and the drain hole is plugged if this is a side by side the drain is in the very bottom back. sounds like it is actually a two problem situation you have. watervalve bottom back outside frige and drain in the back bottom of freezer.
Sep 23, 2012 | Frigidaire PLHS267ZA Side by Side...
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Water is leaking out of the front and back of frigidaire side fre
Clear the bottom of the freezor so you can get at the drain. then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the refrigerator side as well.
Good Luck,
Gilsh
Nov 29, 2009 | Car Audio & Video
My frezeer side has water leaking out and freezing in the bottom of the freezer
remove food
clean/defrost ice built up inside freezer at bottom of evap coil tray where water leaks down in a defrost cycle at back of freezer.
clean the drain line, find it under the fridge it drains into a pan, then blow back up though it.
Oct 02, 2009 | Frigidaire FRS23H7C Side by Side...
My side by side Frigidaire refrigerator is leaking water on the floor and into the freezer and freezing
DRAIN IN BOTTOM REAR OF FREEZER IS STOPPED UP.DEICE WITH BLOW DRYER,USE TURKEY BASTER WITH HOT WATER.FORCE WATER THROUGH DRAIN.AFTER CLEARED ADD ONE HALF OZ.BLEACH TO DRAIN TO KILL ALGEA
Jun 24, 2009 | Frigidaire FRS26R4A Side by Side...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
706 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
