Question about Biostar M7NCD ULTRA Motherboard
M7NCD ULTRA raid drivers
The motherboard has the AMD 2900 XP 400MHz bus. 512mb RAM with 8gb and 80 gb IDE hd. I have a 250gb SATA WD that works fine as a slave in another pc. I can't even see it in BIOS or WinXP Pro?
I've tried all drivers I can find on web.
In device manager I have correctly installed VIA SATA RAID controller.
Under other devices it's trying to install ? RAID Controller.
All help is appreciated.
  • Anonymous Feb 23, 2009
  • 63 Answers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Posted on Nov 19, 2007
Dear i am using ms-7142 v-1 motherboard. now i,m using ide 80 gb i want to connect 160 gb sata hdd.its not showing bios also.hdd is working fine.i reinstalled os.and installed sata raid driver
first thing I would try is seeing if the sata drive is recognised on another motherboard if at all possible ,in order to eliminate the motherboard as the issue.If it is recognised on a different motherboard it is more than likeley a bad cable or a bad board .
Sep 23, 2014 | Computers & Internet
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
500gb hard disk supported by intel D101GGC
This D101GGC Motherboard supports both IDE and SATA.
Mar 05, 2010 | Intel D101GGC Motherboard
Can't install windows XP on my KN8 ultra
I believe you are using a sata drive not ide, correct? The problem is that vista has built in drivers to support your boards sata/raid controller, winxp does not. to work around this you need to go here -
Abit website. for your board - socket 939. KN8 ultra file called NVRaid Installation disk. click on picture, it will download the zip file. extract the files to an empty folder (create one). Then run RFDgen.exe program. It will create the floppy you will need. I hope you have a floppy drive, if not try a usb one. If it has a problem creating the floppy, copy the files in the folder floppydisk to your floppy. there is a readme.txt file in that folder as well that should help explain which option you should select when you install windows. So... once you have the floppy start your computer up with xp disk in and as the screen turns blue, you will see at the bottom of the screen a message - press F6 to select additional drivers. Do just that, a couple of times to be sure. then it changes to press F2, just sit back and wait. eventually it will come to a screen asking if you want to specify additional drivers. press S and the next screen will show you the drivers it found on the floppy. select the one for your configuration (can be changed in the bios). and then windows will load fine. this is necessary for all new systems with sata/raid installing xp. take care.
Feb 10, 2009 | Abit KN8 Ultra Motherboard
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
Can't install Hard Drive MS Server 2003
HI.. please specify the ASRock motherboard model, check whether it is using which chipset as SATA Controller... ICH6 or ICH7 or ICH8 or ICH9
ICH5/6 Sata Raid drivers
ICH6/7/8 Sata Raid drivers
Please tell me if u need anything else.....
Siddesh Prabhu
Aug 30, 2008 | Intel Motherboard
try running scandisk on the floppy disc to fix errors with the txtsetup.oem file.
Aug 16, 2007 | Asrock K8 Combo-Z Motherboard
Windows did not detect SATA during installation
You need the manual to your motherboard to set it up in the BIOS. In the drop down menu select M7NCD ULTRA. I hope this helps. Let me know.
Jun 30, 2007 | Biostar M7NCD ULTRA Motherboard
Biostar M7NCD ULTRA Motherboard Logo
619 people viewed this question
Top Biostar Computers & Internet Experts
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
