Question about Refrigerators
Fridge not cooling and freezer intermittent
I discovered my freezer (Whirlpool ARC 7720) had defrosted so I switched it off and on again and it seemed to work fine but only for ~10 hours so now I have to reset it every morning and evening. Now the fridge does also not seem to be cooling. Anyone know what the problem is?
many thanks
  • cahornsey Jul 15, 2009
    I can't locate the defrost timer, any ideas?
    Sergeant:
  • 212 Answers
Your defrost cycle is every 10 to 12 hours depending on how old the defrost timer is. if your building up frost on rear wall of freezer section then your problem will be that your units defrost cycle has failed. you turning it off lets the frost melt in return you are restoring air flow over the evaporator. ohm out your defrost heater and defrost bi-metal. could be defrost timer.
Posted on Jun 25, 2009
Hi my freezer is freezing intermittently. For example, it will freeze the ice cream and then the next day the ice crease is soft. it may go two days working fine and then back to the same problem again...
Hi, The defrost timer is sticking on sometimes...replace it..
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Whirlpool GD5SHAX Side by Side...
Whirlpool fridge/freezer ARC 7050
see if you can remove panel inside freezer to see if its full of ice all over condenser .Even if you already defrosted for 1 day..If its full of ice ..Then the DEFROSTER COIL is not working and not melting the ice on condenser and then stoping the cycle therefore compressor will stop running..Also there should be a a couple of thermal switches on the condenser(two wires) if this is bad then there is no cycle..goodluck
Dec 06, 2007 | Refrigerators
The self defrost seems to not be working. I just replaced the blower fan in the freezer. Is there a switch or something that could go bad???
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
I have a 19 cu.ft. refrigerator. Freezer seems fine but fridge is intermittently functioning. Can I fix this myself or I need help from specialist?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 29, 2010 | Admiral Refrigerators
FREEZER SEEMS TO RAISE IN TEMP. AND ICE STARTS THAWING THEN STARTS FREEZING AGAIN. FRIDGE SIDE SEEMS NOT AS COLD ALSO.
heatman101
Nov 18, 2010 | Whirlpool ED2GHEXN Side by Side...
The fridge dont work properly, the the temperature of the freezer and fridge seems to be the same and it switches off for a long time and goes on again causing the food to defrost and go bad.
Usually that is caused by the defrost timer/control sticking on...
heatman101
Nov 03, 2010 | Refrigerators
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
I have a whirlpool N387 that freezes in the freezer section but does not cool the fridge. I believe the problem may rest with the fan located at the back of the freezer. It seems to work intermittently. I...
Good initial troubleshooting...
In addition to lubricating the fan ... check the door button that activates the fan. Sometimes closing the door may not fully activate the switch .... some piece of plastic might be broken preventing full activation of the switch.
If the door switch looks fine and the fan runs .... then check the pathway that the air flows from the freezer to the fridge. Sometimes even though the freezer does not look bad with ice ... the pathway can get blocked with ice buildup. Has the total fridge been defrosted/deiced recently?
Or of course ... the fan may be on it's last legs ... but usually they last a long time.
Helpful?
Good luck on your troubleshooting
Feb 08, 2018 | Whirlpool Refrigerators
Whirlpool double door fridge side is not cooling,
sounds like a defrost problem. check to see if there is any frost buildup in the back wall of the freezer. if so, it is not defrosting like it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
218 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
