Question about Kodak EasyShare Z760 Digital Camera
Kodak easyshare z760 can go to favorites and not turn on to take a picture
I have had problems withe the lens dot retracting and last night i had not turned on the camera in about 1 year and the screen flashed "Camera error #E45 see users guide"and i did and there is no #E45 rule or tip or anything lie that. so i retracted the lens and it stillwon't work please help me with the problem
  • 6,831 Answers
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Posted on Nov 09, 2010
Kodak z760 lcd screen will not work in the auto
It could have something to do with the batteries/ battery compartment: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 14, 2010 | Kodak EasyShare Z760 Digital Camera
How do you fix a light sensor that causes the
Please readjust the ISO.
In order to find a pattern please experiment: For example: Try Different SCN (If you're experiencing this problem with your night pictures try and use SCN night, the logo shows a moon and a star, with or without Flash.
I hope it works out.
Dec 17, 2009 | Kodak EasyShare Z760 Digital Camera
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Lens want retract kodak easyshare z760
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
Mar 22, 2009 | Cameras
Trying taking indoor pictures in the "Night Portrait" or "Night Landscape" modes in the "SCN" command. Be careful not tho shake the camera in these modes.
The "Party" mode works well if the people in the picture are close to the camera.
You could also play with the settings in the "P" command to adjust the amount of light entering the camera.
Good luck.
Jan 08, 2009 | Kodak EasyShare Z760 Digital Camera
Lens jammed will not retract, canon pc1147 zoom
I have had the same issue were the lens would not retract. took it in for extended warranty work. lens now retracts but takes lousy pictures.
When I purchased this camera family members ran out and bought thiers shortly after I did. One by one the same issue has happend to their v1253's.
I dissmantled one and found that there is a tiny battery on the power board inside of the camera. apparently the tiny battery's life is about 1 1/2 years. This battery is not serviceable as it is welded in place. I am not one hundred percent sure if this is the cause but it makes sense.
It would be nice if kodak would own up to this issue and make good on repairs as they did with my kodak 5500 all-in-one printer and it's crappy print head. Kodak has sent me 4 print heads in the 2 years I have owned it.
I have 5 of the v1253's in my family and every one of the are dead. I would think a $250 product should last longer than 1 1/2 years.
hope this helps.
Aug 16, 2008 | Kodak EASYSHARE V1253 Digital Camera
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
Kodak EasyShare C533
When I turn on the camera. the lens will not extend. The screen
will not show anything but a message, " date & time are already
programmed". No menu item works. Pictures cannot be taken.
Apr 21, 2008 | Kodak EasyShare C663 Digital Camera
Camera Won't Stay On
hi change the battries good luck
Apr 16, 2006 | Kodak EasyShare V550 Digital Camera
Kodak EasyShare Z760 Digital Camera Logo
54 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
