Question about Philips SA2315 MP3 Player
SA2315/37 The software for the above product will not install on windows vista what can i do to install it
    Problem Solver:
  • 14 Answers
Re: SA2315/37
That is a common problem these days, and one of the difficulties about owning a new OS. Manufacturers will need to provide their products' users with drivers that will support Vista when they are not cross compatible. I would contact your item and see if they are working on a resolution. YOU may be able to use similar products, different manuf drivers to get yours recognized. Do a GOOGLE for your product and see if there are any others out there that have found drivers for your player. IT is possible to set a computer up dual-boot OS's, Windows XP and Vista CAN coexist. Hope this helps!
Posted on Nov 05, 2007
0 characters
3 Points
Your install disk is made for windows xp. If you provide me with the details of your player I can give you the driver download link.
Apr 21, 2008 | MP3 & Digital Media Players
My igolf neo won't work with Windows 7 if i try
I fixed this problem by going to Start>Control Panel and uninstalling the Java 64-bit program. It is incompatible with the Neo sync application. The other Java program on there is compatible. It worked immediately without even restarting. (I tried the above Best Solution, but on the newer computers, I get a message saying the Vista driver is only for Vista, not for Windows 7).
Jan 30, 2010 | NEO iGolf neo MP3 Player
The cd is for Windows 98/ME but I have Vista.
As you never mention the Model, the best i could do is to provide you with the below link :-
Enter Model number and Download the Software.
In case if you do not find it in the above link, kindly inform me so that i could search that for you.
Do mention Model number as well.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 13, 2010 | Jwin MP3 Player
Cant get the stupid thing to be redognised by vista usb drivers for the mp3 not installed or regnoised
Hi There,               Vista should reconize  it as a usb divice and look into the storage space. Just try to use vista in the control panel and goto add new hardware if ask for driver just but in the software mini cd it came with. I have no problem with mine. If it does not work then you might have a faulty product or you should ask a vista tech how to identify a a usb divice mp4 player to windows. I know the pmp 8308 Missil is compatible with Microsoft Window Vista. It should just be plug and play and identify as a usb device so you can drag and load your videos or mp3s or pictures or even text into your ebook on the device. I hope I helped a bit. Good Luck
May 04, 2009 | MP3 & Digital Media Players
Sandisk is not detected in Vista operating system notebook
See the FAQ here -
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
View/c200: Turn on & press and hold the rewind button while plugging into the PC
Dec 30, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sansui 2gb multimedia player san20044- wont transfer music
hi just brought same product today and same thing was happening to me.I am using vista I solved the problem by formatting the multimedia player then drag and dropped files voila it works
Dec 06, 2008 | MP3 & Digital Media Players
The ez-installer disc wont install on my computer
Make sure that your computer's OS matches the product specs for your player. If it says Windows XP only, it may not work with Windows Vista. If it doesn't say Macintosh, then it is not Maac compatible. Check the manufacturer's website to see if they have an updated version of the software - many manufacturers, like Philips, now have updated software available on their website to support Vista and other OS's.
-Tha Mp3 Doctor
May 24, 2008 | MP3 & Digital Media Players
Error Message 2738 ipod shuffle install
Symptoms In some instances, the iTunes and QuickTime Installers may unexpectedly quit during the "Preparing to Install" stage of the installation with the following message:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738. In some cases, the error message may read
"iTunes could not be installed because Visual Basic Script (VBScript) is not installed or has been disabled. Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Products Affected iTunes 7 for Windows, QuickTime 7 (Windows), Microsoft Windows 2000, Windows XP, Windows Vista
Resolution Windows XP or Windows Vista
Download and install iTunes 7.6 or later.
Dec 26, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Philips SA2315 MP3 Player Logo
69 people viewed this question
Top Philips MP3 & Digital Media Players Experts
 Mike M
Mike M
Pieter Vleeshouwers
Are you a Philips MP3 and Digital Media Player Expert? Answer questions, earn points and help others
