Question about Microsoft Xbox Console
360 open tray disc is in - Microsoft Xbox Console
SOURCE:
  • 13 Answers
SOURCE: can't open disc tray
Alot of the xbox tray issues can be fixed by taking the box apart and bending the lid on the rom drive very slightly. It seems to be associated with the Samsung drives. Also if any one has tried hacking the box and made a mistake, the drive could of been bricked during the flashing process. Good Luck
Posted on Oct 03, 2007
bobntina
  • 29 Answers
SOURCE: xbox 360 tray doesn't open
I have had 1 other person talk to me about this and I had him bring me his 360 to look at and what I found was that his 360 overheated and it actually warped the plastic around the tray. I changed his tray sold him a usb cooling unit and he was been good ever since. When it sticks there is not a lot that can be done other than change the tray. Not an expensive fix but you will have to crack the case to change it. If you have any warranty left cracking the case will void it. If you have any warranty left call microsoft and they will change it for you. If you are out of warranty you can change it yourself if you feel comfortable with it and if you don't I would take it to a game store (GameStop for example) and they can change it for you. The tray unit runs probably about 40.00 and they can change it for probably about 30.00 (it is about a 20 minute job so I would not pay more than that).
Best,
Bob
Posted on May 11, 2008
  • 34 Answers
SOURCE: I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Posted on Jun 23, 2009
justin217
  • 85 Answers
SOURCE: My xbox 360 wont play discs - keeps repeating open tray.
Call microsoft at 1-800-4-MYXBOX
Posted on Jul 15, 2009
SOURCE: when I put a disc in the 360 tray, it just says open tray
9-11-01 caused that prob go back in time and stop it
Posted on Sep 13, 2009
Yes when I try to open the Xbox 360 disc tray the power button in the center flashes as if the disc tray is opening, but doesnt open. it flashes even when i havnt pressed a button for it to open the d
Try turning off the 360 then turning the xbox on its side, turn the machine back on holding the eject button and the power button together for about 30 secs then the machine should function normally
Jun 19, 2014 | Microsoft Xbox 360 Console
My x-box 360 console will not read disc it prompts me to open tray close tray reading then back to open tray is there a solution to this problem i am having with my 360
it might be a bad disc or your lens on the drive is burnt out. try other disc, if the same problem you need to contact microsoft.
Mar 23, 2011 | Microsoft XBOX 360 ARCADE Console
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Feb 16, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Open tray
Hi, this is caused because your laser is either dirty or starting to fail. Take your 360 and turn it on, then open the tray. As soon as the tray is open, unplug your 360. Now with the tray open use a can of compressed air or an air compressor and blow out the DVD drive .And see if it is because your laser is dirty. Take your 360 and plug it back in and try putting a disc in it. If it still gives you the "open tray" error, then your laser is not reading the disc and needs to be replaced.
Aug 21, 2009 | Microsoft Xbox 360 Console
Disc tray won't close
Whenever you need help with your Xbox or Xbox 360 accessories, allways check out Xbox Customer Support
The answer to your question is quite long, so here's a link.
Xbox 360 disc tray help
Hope this helps
May 20, 2009 | Microsoft Xbox 360 Console
When i put an xobx 360 disc in it says to open tray
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Apr 05, 2009 | Microsoft Xbox 360 Console
The Disc Tray won't open!
press the button the it might go on if not take it back to the shop and say the disk tray wont open lol]
Jan 25, 2009 | Microsoft Xbox Console
Repair
if it won't open, turn off the console and remove the faceplate and try to eject the button. if it still won't open get a paper clip and straighten it out. you need to locate a small hole that exactly fits a straightened paper clip. it's located just below the silver lining of the disc tray about one and a half (1 1/2") inch from the left side of the disc tray. insert the paper clip into that hole and it should pop up the disc tray enough for you to be able to pull the disc tray all the way.
if it doesn't work there are still 2 more small holes that you can locate. the 2nd one is just beside the first hole and the 3rd one is just under the second X on the XBOX 360 text on the disc tray. try those two holes if the first hole doesn't work.
Jan 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
