Question about Gigabyte GA-7VAXP Ultra Motherboard
Display problem troubleshooting
Gigabyte ga7vaxp - i plug everything in properly and turn it on. My computer starts up and powers on but nothing is displayed on the moniter. iv changed my graphics card with an older type and still nothing. Before i re-wired my computer it started up for aprox 5seconds then it turned itself off, also nothing was displayed. After i re-wired it i started to experience nothing being displayed even though the pc stayed on. Iv had a computer programer look at it and no soloution has been aquired. If anyone could be of assistance through e-mail i would be most gratefull...cheers Mr craig Gleave :-
  • 208 Answers
Re: display problem troubleshooting
Sounds like memory or cpu issue. could be bad board too
Posted on Nov 05, 2007
0 characters
3 Points
Im having display issuse with my GIGABYTE GA-880GMA-UD2H AM3 AMD 880G HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard .. everything is plugged in and when i turn it on everything lights up but i cant...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Apr 16, 2011 | Gigabyte GA880GMAUD2H AM3 AMD 880G HDMI...
When i press cpu on button. monitor is not starting, nothing happen on screen
Problems that you experience most often occurs on the computer,
To determine whether this problem occurs because one of the hardware in your computer casing,
first, you must make sure that your monitor is 100% functional.
If it's been identified, and proved your monitor no problem, this means that the problem comes from the hardware in your computer casing.
ways to identify where a hardware problem,
you should make troubleshooting prior to each of the hardware in your computer casing.
troubleshooting steps.
> Open the casing cover your computer and remove the ram in the ram slot on your computer by pressing the two pins at the end of slot (Make sure the electrical power source is turned off first)
> Sweep ram slot with a small brush or small paint brush is not used (new)
> After cleaning the ram slot, use the eraser to clean the copper surface on the ram you are.
> When you're done, plug the ram in the slot. (If you have a new ram to do the troubleshooting is better)
> Reattach the power source on your computer and then switch on your computer.
> Still not working?
> If you use the display card, remove the display card and do the same as you did on your ram and ram slots.
(If you're not using the display card, the better you get the display card to make the process of troubleshooting)
>Turn on your computer.
(If your computer is still experiencing the same problem though has to do the troubleshooting on the display card)
> Get at / ATX new power supply to do troubleshooting, (damage to the power supply will also cause the computer not display
If the computer still can not function normally means that you have the problem still appears,This requires you to perform more detailed troubleshooting process. First, you need to provide a motherboard and processor is still working (new) to do this process.If you already have all the equipment, you can start to make the process of troubleshooting your hardware one by one.I believe there is enough equipment for you to perform troubleshooting, problem you will be able to identify you and you will be able to solve by itself.
good luck
Jul 22, 2010 | Mercury KVM266PM-U (KVM266PMUD1600)...
I have a dell inspiron 1100 approx 7 yrs old. Try to start up, no display. LCD for power and battery (ac power) light up, no hard drive light. Reseated everything, still nothing. Also shuts itself down...
Since there is no hard drive light, you could try unplugging it first, and try to boot and see if there would be any display on the LCD. If yes, you already isolated the problem that it is the Hard drive causing the " no display".
Try to do also the following: (draining flea power)
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Hope to hear from you soon.
Jan 24, 2010 | Dell Computer Refurbished PE3250 SYSTEM...
New build, everything powers up but no display
Does the system beep when you first power it on? It sounds like the on-board viedo may have failed you. Do you have any other PC's around that you can test the monitor with? If it is the on-board video, you can use one of the expansion slots available on your mobo. There's a PCI-E x16 and a PCI-E x1 available on this board.
Jan 02, 2010 | Gigabyte GA-G41M-ES2L Motherboard
I have a Motherboard gigabyte GA-8PE800. when i
The ATX 12v ( 4 pin Connector ) is For The CPU Power.
This could Indicate, either A Faulty CPU.
Or a fault To The Motherboards ( BGA ) or CPU Socket Holder.
Or alternatively, The Actual PSU Itself is Faulty.
You can obtain A CPU Socket Tester from e-bay. And A PSU Tester.
Hope This Helps Mike @ Compurepair.
Oct 16, 2009 | Intel Motherboard
Hi,my motherboard in not booting after connecting new power supply,power supply is OK,motherboard lights are on.But when start button is pressed its not showing anything
Try this site // tools cheap !! You need PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Price: $2.57 free-shipping_small.gif PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card costs $2.57 and free shipping.Great company.need help PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Aug 22, 2009 | Motherboards
No display
try this ,unplug power cord turn off computer, (if you have switch) there should be no electricity. Remove little battery that you have on your board,wait for 10 sec. and pull it back in, that will restart cmos to default values.PLug power cord, turn on computer. Post me what happened.
Jun 09, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
GA-K8VM800M and GV-N76G256D-RH compatibility
Perhaps your power supply is not powerful enough for the new card.
Mar 01, 2008 | Gigabyte GA-K8VM800M Motherboard
if it does not respond at all......i mean no fan no lights no anything.....then double check that your power supply is good.....if it is and you are sure your chasis connectors are placed on the proper pins then you could have a bad motherboard or cpu.......of course more troubleshooting should be attempted before drawing this conclusion (removing one part at a time, etc.) but no power is never a good thing.
Dec 11, 2007 | Gigabyte GA-8I945GZME-RH (0818313003041)...
CMOS battery drains after one startup. Gigabyte GA-K8N-SLI
OK lets see here! Make sure your CMOS jumper is set properly on the board(Set to Normal) or Did you configure your bios after flashing the bios(going into bios and Load Optimized Defaults!)? or I don't think it would be another device in the system, but you can try troubleshooting by starting up with only what you need to run the machine (Mobo, memory harddrive, keyboard and mouse) then one by one adding devices back! or Did you have problems like this b4 you flashed the bios! Try flashing the bios back to an older version! post back if anything new or if i'm way off! Good Luck regards, babb
May 03, 2007 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
Gigabyte GA-7VAXP Ultra Motherboard Logo
145 people viewed this question
Top Gigabyte Motherboards Experts
Brian Sullivan
Brian Sullivan
Are you a Gigabyte Motherboard Expert? Answer questions, earn points and help others
