Question about Vans Cirro Snowboard Boots
Hello, I have damaged one of the internal boots of my vans Hi standard N º 12 (The left internal boot. Does someone know where I can obtain one of supply(replacement)?
    Problem Solver:
  • 14 Answers
You can call vans and talk to them or just go to your local snowboarding shop they should have some supplies
Posted on Jul 10, 2009
Problems to obtain a complete system boot at first try.
See if you can boot to safe mode. Run check disk on the hard drive. Make sure the BIOS battery is ok.
Oct 29, 2017 | Dell Computers & Internet
Wiring diagrams for
Hi everyone can anyone obtain a diagram of the wiring loom for the boot/trunk. Someone has cut two wires from the luggage shelf contact and i do not know where they go. having serious issues and need help thank you
Jan 06, 2014 | Cars & Trucks
How do i recover data from internal memory phone keeps cycling through boot
hi dear
seems your phones boot area is damaged thats why its not booting up properly...only way to recover your data is to repair only boot section by any ressurector softwares but its requres profesinal soldering skills..........you can contact me for further details on boot repair +919781220810
Mar 24, 2012 | Samsung S8300 Ultra Touch platinium-red...
When I make a left turn there is a noise coming from the front drivers side wheel, someone told me it was the boot, where is it
Hello rkayet,
They may have been referring to the CV axle boot. When the CV axle boot gets damaged dirt and water get into the CV joint and wear the internal parts, this typically causes a clicking noise when turning.
Unless you have the tools to rebuild the CV axle it's best to buy a rebuilt CV axle (sometimes called a half shaft) from your local auto parts store.
Regards,
netvan
Mar 05, 2011 | Oldsmobile Delta 88 Cars & Trucks
Hello i have a compaq presario 5000 when i turn
This is a compicated problem. First when it boots enter setup by pressing the F10. Once you are in set up reset all settings to default. Save changes and exit CMOS. If that does not help the situation have someone make you a boot disk, reenter setup and put the floppy as the first boot drive and then CDrom. Insert the boot disk, follow the instructions to boot. Once you are up and running try to roll back the computer to the last recovery point that worked. If that does not work you may need to see a local repair tech.
Feb 04, 2010 | Compaq Presario 5000 PC Desktop
I can't boot with the 1.5GHz processor. A 3.0Ghz
hello its need minimum 1.6 ghz processor. there no option .
Dec 03, 2009 | IBM NetVista X41 PC Desktop
Hi i have an acer aspire 3690 and cannot boot the pc as it says unmountable boot volume. i dont have the recovery cd or bios password as bought from someone i used to know in the uk and im no longer living...
Hello
Thank you for using
FixYa for your problem
If you receive the “unmountable boot volume” error and have an installation disk, you still have a chance to save your system.
1. Insert your XP installation disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
5. Type exit and press the Enter key to reboot your computer.
If all went well, you should now be able to boot back into Windows without a problem!
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Acer Aspire 3690-2196 Notebook
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Presario 2200 won't boot up
Hello
your hard driver is broken or it can be your motherboard sata controller.
sorry
replace your hard drive and run a restore. you can get your restore cds from HP.
check if you have warranty left. then you can go to nearest hp reseller and get your motherboard or hard drive changed for free.
good luck
Aug 10, 2008 | HP Compaq Presario 2200 Notebook
Need help
Your boot record is corrupted. You'll want to boot to the Windows 2000 Recovery Console.
http://support.microsoft.com/kb/229716/
Try running the chkdsk /r command first. It may take about 30+mins to finish. If that doesn't get it, then you'll want to try fixing the boot record:
command-> FIXBOOT loadTOCNode(3, 'moreinformation'); fixboot drive name: Use this command (where drive name is the drive letter where the boot sector will be written) to write the new Windows boot sector code on the boot partition. This command fixes problems where the Windows boot sector is corrupted. The Emergency Repair process also fixes the boot sector. This command overrides the default of writing to the system boot partition.
command-> FIXMBR loadTOCNode(3, 'moreinformation'); fixmbr device name Use this command (where device name is an optional device name that specifies the device that needs a new MBR) to repair the master boot record (MBR) of the system partition. This command is used in scenarios where a virus has damaged the MBR and Windows cannot start.
WARNING: This command has the potential to damage your partition tables if a virus is present or a hardware problem exists. This command may lead to inaccessible partitions. Microsoft suggests running antivirus software before using this command.
The name can be obtained from the output of the map command. If this is left blank, the boot device's MBR is fixed, for example:
fixmbr \device\harddisk2 If Fixmbr detects an invalid or non-standard partition table signature, it prompts you for permission before rewriting the MBR.
Jan 17, 2008 | Dell Latitude CP (0001849d-38380-968-p06e)...
Vans Cirro Snowboard Boots Logo
116 people viewed this question
Top Vans Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Vans Winter Sport Expert? Answer questions, earn points and help others
