Question about IMSI TurboCAD Pro 15 Full Version for PC
When entering degrees minutes and seconds (as per lat and long) into Turbocad .. what is the symbol you use for degrees?
  • 334 Answers
Hey there, this is easy. HOLD the ALT key down and with the ALT key held down type 0176 on the number pad. DO NOT use the numbers on the top row of your keyboard, it must be on the numeric pad.
seth
Posted on Jun 29, 2009
How do you write numbers in degrees, minutes and seconds?
In Run/Mat press OPTN key. Press F6/Next until you locate the ANGL tab. Here what it will reveal. To enter the values in DMS, use the F4 key.
May 28, 2014 | Casio FX-9750GII Graphing Calculator
Sin 43 degrees 30'
Press SIN 4 3 2ND [ANGLE] 1 3 0 2ND [ANGLE] 2 ENTER
2ND [ANGLE] 1 gives you the degrees symbol, 2ND [ANGLE] 2 gives you the minutes symbol. If you need seconds, use ALPHA ["] (on the + key).
Note that this usually won't give you an EXACT value, but only a ten-digit approximation.
Dec 05, 2012 | Texas Instruments TI-84 Plus Calculator
How do i input degrees minutes and seconds, on a casio fx992s, i can input the degree but not the minutes
Enter the degrees, press DMS, enter minutes, press DMS, enter seconds.
You must input all three items, even if they are zero.
The DMS key is marked with the degrees, minutes, and seconds symbols (circle/single-tick/double-tick), and is located two keys above the 8 key.
Jan 25, 2012 | Casio Office Equipment & Supplies
How do you input minutes into the calculator. Yes, it displays degrees but not minutes like a TI help
Press the degrees/minutes/seconds [o ' "] button after entering each part of the angle. It will appear on the screen as the same (degree) symbol after each part, but the calculator will recognise that each part is different and compute accordingly.
Sep 05, 2011 | Casio FX-115ES Scientific Calculator
I can't figure out how to use the degree, minutes, and seconds button to get to a decimal number.
Enter the number of degrees, press DMS, enter the number of minutes, press DMS, enter the number of seconds, press DMS. Press S--D. If you get a fraction, press S--D again.
DMS is the degrees-minutes-seconds button located above the ENG button, S--D is the symbolic--decimal button located above the DEL button.
Feb 01, 2011 | Casio FX-115MS Plus Calculator
I'm using the Casio fx-115ES model. When i try to put in 52 Degrees, 10 minutes, I dont seem to be able to do this. I key in the numbers 52 then hit the "degree, minutes seconds" button and i get the...
When entering the information it only shows the degree symbol. If you press enter or type inthe formula, then the answer will show the Degree, Minutes, and seconds. It seems to be the way it was program by Casio. It still seems to work fine for entering that information
Aug 03, 2010 | Casio FX-115ES Scientific Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
Converting between Decimal Form and Degrees, Minutes, Seconds
Enter the angle in degrees-minutes-seconds using the single-tick (') for all three parts. Do NOT use the degree and second symbols. In my TI-86 manual, it's on page 285.
Jan 15, 2010 | Texas Instruments TI-86 Calculator
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
I do not know how to load latitude and londitude into my tomtom. I am going to Bad Liebenzell in Germany (with caravan) The Latitude is 48.87329 (I do not undestand that because lat/long is usually...
Latitude is N or S, longitude is E or W, correct.
When entering degrees, minutes and seconds, you dont have to type the double apostrophe at the end off seconds, the device will understand...
ALT and LONG can also be seen as decimal degrees,
as in your case N48.87329 E8.6923
The TT device understands them both, just type them in....
Sep 03, 2008 | Tomtom GPS
IMSI TurboCAD Pro 15 Full Version for PC  Logo
166 people viewed this question
Top IMSI Computers & Internet Experts
Hardware and...
Braden Bills
Braden Bills
Level 1 Expert
Are you an IMSI Computer and Internet Expert? Answer questions, earn points and help others
