GA-EP35-DS3L no video, no beep, with green, green, orange and red color
    Novelist:
    Champion:
  • 256 Answers
Please note that the motherboard is no the only part of a computer. In your case I would re-install the OS (I presume windows XP SP2). You say no video, no beep (does that mean the entire sound is missing?). I would say that most likely a re-install of the OS and drivers would fix it!
CONSTANTIN (arzconst)
Posted on Jun 26, 2009
How do i wire red white and yellow rca to an xbox 1 av plug. my av plug has blaack white orange and green wires
In the old school standard AV: Red and White are usually audio channels (Red:Right - White:Left), Yellow is video.
Orange can be coax audio, (both L&R channels in one cable). Before digital (optical) came out, some receivers actually had a coax (orange) jack in the back. Radio Shack sells a splitter if necessary.
In higher resolution systems video is separated into three colored cables: RGB or Red, Green, Blue
called 'component' video. The green cable carries Yellow, the blue cable carries (PB) Blue and the red cable carries Red (PR). And with today's tech, the component signal is carried YCBCR as (digital video.) cf. http://en.wikipedia.org/wiki/YPbPr
Component 'wire colors' are there just to remind us. If your TV has "Component" input. Try green to green, white to yellow and black to red. Orange to audio (splitting L&R if necessary)..
Also, here is a PS3 link that might help: http://www.ps3hax.net/showthread.php?t=9238
Good luck !
Apr 23, 2011 | Video Game Consoles & Games
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
Hello, I recentily buy a GIGABYTE GA-EP45T-UD3LR motherboard, it workd great, but don't have the "beep" sound when boot, I test via software the internal speaker and it works, is this correct ?, I hear...
1 beep is the BIOS signaling all is well after testing components inside and attached to the pc. On newer motherboards it's heard only when you have something attached to the USB connectors . Do a simple test: boot with an connected USB device, like a running printer or an memory stick - you will hear the short beep as you were used to.
Apr 13, 2010 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
No power to GA-EP43-DS3L motherboard
When connecting your psu and its atx connector to the mainboard, have you connected the +4 connector ? If your psu does not have this extra +4 connector, you may need to buy one.
Also check you have connected the cpu power (12v 4 pin plug)
Nov 12, 2009 | Gigabyte GA-EP43-DS3LR Motherboard
GA-EP35-DS4 motherboard does not load
is it in warranty..?? if not..
do it if u r a professional..
check the following:
1) the cmos battery (above +3v)..replace with a standby n see..
2) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistace n many more..resulting an increase in heat..
3) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
4) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
5) ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector....
..plz give higher priority to step3 & 4 (as listed above) CAREFULLY..
immediately contact ur system admin/vendor....
Nov 07, 2009 | Gigabyte GA-EP35-DS4, LGA775, Intel P35,...
I have a GA-EP35-DS3L/S3L Motherboard and i want to update the BIOS driver.
Hi go here and insert the motherboard you have, there is a slight difference between the GA-EP35_DS3L and the S3L. Download your link and follow the instructions that come with it.
Click Here
Hope this helps
Sep 25, 2009 | Intel D850MV Motherboard
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
Color is weird.
Component Video Jack was loose.
Dec 14, 2008 | Sony KP-48V45 48" Rear Projection...
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
