Question about Samsung AW1003M Air Conditioner
Weater inside air conditioner is good?
I recently bought a 1.5 tonSamsung A/C.the service engineer did not open the drain plug as he said that the water in the tray will help in cooling and there will be less pressure on compressure?Since it is 40degree C here.Is it true?Please let me know
  • Samsung Master
  • 8,220 Answers
The puddle of water at the base gets swept up by the slinger blade and contributes towards cooling efficientcy.
Posted on Jun 25, 2009
What is the starfoam for in my airconditionar for?
Hey friend, thanks for your inquiry!
The sytrofoam inside the air conditioner is part of the duct work and it also helps to hold colder temperatures. The new air conditioners do not have drain holes but instead recycle the water inside your appliance to help cool the internal components. I hope this information is helpful. -Matt
Aug 30, 2014 | Frigidaire Heating & Cooling
I bought lg portable 9000 btu air air conditione two days ago. The unit fills up with water every few hours and the drain plug does not work. I have to move I it outside and tip it over to get the water to...
Hey there. I bought the same AC unit and was experiencing the same issue. Wouldn't drain, etc...
I'm happy/embarrassed to mention that there is a rubber grommet inside the drain plug that I did not see before. It looks like it's part of the plastic drain, but it's a rubber cap. So when you unscrew the plastic cap, there is another rubber plug you have to pull out.
Doh!
Hope this helps.
-C
Jul 05, 2012 | LG LP0910WNR Air Conditioner
Water builds up in Air condition and does not drain out...So when airconditon is turned off, the water drains inside home rather than outside. How do I fix this?
Check the filter and service it while your at it. You may have a drain hose with this unit if so it could well be plugged so you sill have to pull it to get to it and clean it out as well as the drain tray. If you donot havea hose then it just needs to be tilted to theoutside about 1 inch or so. hope this helps let me know Jon
Aug 04, 2011 | Sharp AF-S85FX Wall/Window Air Conditioner
Water leaking out of frigidaire portable air conditioner at left back bottom corner? Model FAPO94P172 or FAP094P172??
First, have you drained the tank recently. If not, the warning light or auto shutoff failed and the tank may be overflowing. Worse case scenario is the that the tank is dirty and is not allowing the coils to cool and the dripping water you see is from the cooling coils. Since the tank is not removable, it's very difficult, at best to clean the tank.
If you drain the tank and before reinserting the drain plug, try to get about 1/2 teaspoon of bleach in the drain hole. followed by 2 cups of water. Of course you'll have to use a funnel of sort to do this. Reinstall the drain plug and move the unit around so the water and bleach will slosh around. Then run the unit until the bucket is near full again and drain it thoroughly. Look at the color of water draining out, for an indication that there is dirty water. That will be a good indication, that some cleaning of the tank has taken place.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Frigidaire FAP094P1Z Portable Air...
Making a noise and spitting water inside
your ac unit may not be installed properly, it needs a 1/4 inch tilt to allow water to drain properly outside. Also make sure your drain plug is open to allow the water to drain out.
Apr 25, 2011 | LG Heating & Cooling
Condensation drain
on the rear toward the lower side of unit,tip the unit so the rear of unit is 1/2 inch lower than inside of unit,and make sure drain isnt plugged with debris
Jul 29, 2009 | Coleman Mach 15 Air Conditioner
I just bought a Commercial Cool air conditioner, model number CNP12XH9 and have to maznually drain the water (approx 1-1/2 cups) every hour or so. Is thisnormal?
no there is supposed to be a drain tube that goes outside you have to plumb it in, there should be a plug or fitting in the catch tray for the water.
Jul 28, 2009 | Heating & Cooling
My Air Conditioner Drain is plugged. Where is the
-- open the driver's door
-- locate where the air conditioner blower box is attached to the passenger side of the firewall - see photo #1 - look to the immediate right at the top of the gas pedal arm
-- condensation flows toward the front of the vehicle through the firewall at the leftmost edge of the air conditioner blower box - drain channel
-- open the hood and stand next to the front wheel on the driver's side
-- look down at the firewall over the battery and to the passenger side of the brake master cylinder - see photo #2
-- locate the small diameter metal lines running horizontally and attached to the engine compartment firewall
-- locate the hole in the engine compartment firewall panel behind the small diameter metal brake lines
-- this hole leads to the drain opening in the air conditioner blower box mounted in the passenger compartment
-- follow the brake lines as they run from under the vehicle and turn toward the front wheel on the driver's side
-- locate the hole in the engine compartment panel behind the brake lines
-- insert a short length of stiff wire into the hole through the engine compartment panel to unblock the drain hole
Jul 13, 2009 | 2004 Mitsubishi Endeavor
No drain hole
Try to clean your air filter, condenser and evaporator out. If they are plugged with lint the air can't do it's job. Also make sure the fan is working if there is one inside the compressor cabinet. If all these are in good shape you may need to get a leak fixed in the closed system. You probably have a 3 year warranty on it at least. Just call the repair or service number, or check online for a website for that brand.
Sep 22, 2008 | Daewoo DWC063R Air Conditioner
Heating & Cooling Logo
96 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
