Question about Canon GL2 Mini DV Digital Camcorder
Sound recording with external microphone
We hooked up an external mic. Two configurations; XLR to mini-plug directly into the mic input, and a XLR hot-shoe. Both showed good sound levels, but we get no audio when we play back, or when we capture into iMovie.
  • 38 Answers
An instruction manual is available for download at
Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s).
Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
Posted on Nov 09, 2007
How do I connect my CAD GXL2200 mic to my apple laptop?
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Dec 25, 2013 | CAD Microphones GXL2200 Professional...
I just bought the GXL2200 CAD microphone without the cabels,(thought they would've came with), what kind of cable do i need?
As with most microphones, these mics use XLR cables. You can get them online or in a music store in many different lengths. What you need is XLR male to XLR female, though most of the consumer-level stores will probably just call them "mic cables." Note that the thing you're plugging into will need to have an XLR input, and will need to provide phantom power in order for that mic to work.
Nov 09, 2013 | CAD Microphones GXL2200 Professional...
Does the Behringer xm8500 work on it's own, or do I have to hook it up to something? My daughter wants a microphone she can sing into.
All microphones have to be hooked to an amplifier to work. The socket at the bottom with the 3 pins in it is called an XLR jack. You need to plug an XLR cord into that and then plug it into an amp that has an XLR or 1/4 inch microphone input (using an adapter).
If she just wants it for looks, then no, you don't need to plug it in.
Jul 03, 2011 | Behringer XM8500 Professional Microphone
I got a cable to hook my MXL 990 condenser microphone to my computer and i get no sound. it wont record!!!!!!!!! its a 1/4 male to #-pin XLR female cable
Professional condensor type mikes require a phantom power source to work. That will be a balanced (read XLR) connection from source to preamp and the preamp must be capable of supplying the power. These units cannot be used in an unbalanced circuit (like 1/4" or computer mini-pin). Your best bet for the setup would be to get an external power supply box that can also convert the signal from balanced to unbalanced. That would be what the mike plugs into and then that plugs into the computer. You're probably looking at about 50-100 for even a cheap one that will work well. Companies like Sweetwater and B&H should be able to steer you toward a decent basic unit. If you happen to have a mixer (which is why you bought the good mike) then it may have phantom power for some of its mike inputs.
Oct 23, 2010 | MXL 990s Professional Microphone
I get a quiet signal when using the mic.
You should use the mic input of your computer.
If it's not there, use a microphone pre-amplifier.
Feb 17, 2010 | Shure SM57-LC Professional Microphone
I have problems connecting my microphone to my mac computer
what mic do you have? if one with xlr than you should buy usb external sound card with xlr option. can be m-audio. if you have usb mic than just connect with your mac via usb/go to system perferences/sounds/input and higlight your new mic.
hope that helps
Aug 03, 2009 | Logitech (980240-0403) Microphone
Handycam mini dv
I like the Sony VX2100 for the price. It does provide a 3.5mm mic input however be sure that your mic configuration will work with this camera. If you have an XLR mic then you will need an adpater.
The Sony HDR-HC1 also has a mic input but I have had problems capturing good sound from it.
Apr 22, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
Unable to record with external microphone
You may have ruined the phantom power source in your minidisc recorder. XLR microphones use a 48 v power supply.
Sep 25, 2008 | Sony Walkman MZ-B3 Personal MiniDisc...
Canon GL2 Mini DV Digital Camcorder Logo
519 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
