Question about JBL GTO75.2 Car Audio Amplifier
I have a GTO amp. can I use it for ext. use...not for car, how I will connect pls. Sudheesh
    President:
  • JBL Master
  • 1,114 Answers
You can, however the AC to DC inverter that you would need would cost more than the amp.
Posted on Jun 25, 2009
Carborator fuel drain pontiac gto 1964 tripower
Have you ever seen a fuel drain on anything
but power equipment, small engines
I assume you have & are looking at a tripower
carb set up
Why would you need a drain?
I was around & had brand new 65 vette,327/365 carb
I never bought the 1964 GTO, because I wanted
the HI Pro 421 & it only went to the nascar & professional
super stock drag teams.
Jun 11, 2012 | Pontiac GTO Cars & Trucks
My 2006 GTO doesn't want to change into overdrive
wo wo, any major repairs under the body recently?
If u have active warranty then pls stop by the pontiac service centre asap.
it could be one of the following ,
Transmission shifter cable misbehaving,
or
the transmission it self is failing to lock ur given command.
Jul 25, 2010 | 2006 Pontiac GTO
2004 Pontiac GTO 2004
You will need what is called an oil vacuum pump. They are not very expensive (around $20-$30 US) & are usually available at your local auto parts outlet. They are basically an oversized syringe with a flexible rubber or plastic tube instead of a solid steel probe & will usually hold about a metric litre. Hand operated. Use this to withdraw as much oil as you can from the Diff, it is impossible to get every drop. You will also find it handy to refill the diff, but flush it out first with kero or diesel. I also recommend draining all you can in one step, then waiting 1/2 an hour to 45mins and doing it again to get the last bit.
Dec 07, 2009 | 2004 Pontiac GTO
I got a stock ford JBL amp with no wiring diagram i need to know what wires are what i have tryed to test for the power wirer but no luck.
ok on most amps there are two sets of wire ports one for speakers & one for +12v,grd & 12v remote start if you look over each port it will say what port is for what wire if it is in a connector it gets slightly more complecated what you do is with a vm check from wire to chassis ground [like seat bolts] 12v with key off when you cet power isolate wire then turn key on till radio comes on then do the same test for 12v isolate that will be remote start then turn key off &check from the first wire to other wire for ground to find speaker wires connect a regular peace of wire to chassis grd & touch the wires you will here the speaker pop be sure not to hold the wire on long cause it will blow the speaker
Jun 04, 2009 | JBL BP1200.1 Car Audio Amplifier
JBL GTO 301.1ii protect mode
Hello roets81,
Check the voltage at the amp. It's possible that the voltage is either too high (above 16V) or too low (below 8.5V). Also make sure that the amp case is not grounded. If these check out OK, the most likely cause is that the amp itself is defective and requires service.
Hope this helps.
May 27, 2009 | JBL GTO 301.1 Car Audio Amplifier
Jbl gto 75.4 right channel not working
Hi
It's rare that 2 channels will fail simultaneously, are you sending 4 signals to the amp or just 2?
If you are sending just 2, perhaps the problem lies before the amp in the cabling to it, or the output from the headunit. If you are sending 4 signals then there may be a fuse in the amp that drives 2 channels out of the 4. Of course this may be the case should you just be sending 2 signals.
Dec 25, 2008 | JBL GTO75.4 Car Audio Amplifier
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
Bridge jbl gto 600.1
it will over heat the amp posibly blow it.....becareful
Nov 09, 2007 | Rockford Fosgate Power 1001BD Car Audio...
JBL GTO75.2 Car Audio Amplifier Logo
184 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
