Question about Gateway GT4022 PC Desktop
Power went out the other night while my Gateway GT4022 was on. It won't turn back on now, no lights, no fans...replaced power supply, still same problem...thanks
  • Berrman Jun 25, 2009
    Thanks for the quick response, that's what I figured...I think it was time for an upgrade anyway, it's a good excuse to go shopping this weekend...thanks
  • 916 Answers
If the power went out while it was on it may have been given a surge. If that is the case the motherboard is going to need to be replaced. Check the power supply connection on the motherboard if it is discolored then that is the problem.
Posted on Jun 25, 2009
Gateway Gt4022 PC Desktop
Try a different monitor (borrow one). If that doesn't work, you need to take it to the shop.
May 13, 2010 | Gateway GT4022 PC Desktop
My Gateway GT4022 desktop has a problem..... when
Hello
Thank you for using
FixYa for your problem
Is the fan coming from the PSU or somewhere else
Could be just the PSU is blowen
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 28, 2009 | Gateway GT4022 PC Desktop
Hello, Im Daniel and i have a Gateway GT4022 PC Desktop. When i got it it worked great!! but then a year later when i turned on the tower all i could hear was the fan from behind it blowing? Can you tell...
do your keyboard and mouse light up, do they get power, is it only your monitor does not come on and the computer seems to do every thign else ok, or is it you only hear fan noises.
im thinking would it be the monitor at fualt,
would it be the graphics card came loose.
or is it the power supply gone.
How can i be sure that its the power supply or the motherboard that went bad? what can i do to find out?
If you have atx power supply, you can short the green wire with any of the black wires with a paper clip. if the power supply turns on, it is good.
Sep 30, 2009 | Gateway GT4022 PC Desktop
I have a Gateway GT4022 that recently stopped working. When the power button is depressed, the fans will kick over for less than a second and then the system shuts down. It never gets to the BIOS and no...
Power supplies shut off automatically when one of the voltage wires is shorted to ground somewhere. This is why you see the fan kick over for a second and quit. This is probably a bad motherboard.
Jul 29, 2009 | Gateway GT4022 PC Desktop
Gateway GT4022 Motherboard failed
Well, I think gateway is just a computer manufacturer, so if you are still under warranty, you could possibly get a replacement. But before doing anything, and if you are comfortable with doing so, open up the side of the casing, and take a look around, see if any cables seem unconnected.
Jul 08, 2009 | Gateway GT4022 PC Desktop
My gateway gt4022 won't boot. I don't think even at bios. My monitor says that it does receives any signal. I try changing the power supply but I don't think its a power supply issue since the fan kicks in...
Here are different things you can try:
Make sure there are no loose cables
Press F8 when the computer turns on.
Check to see if the lights on the keyboard turn on: this means its posting.
Jul 27, 2008 | Gateway (4000474) Motherboard
Computer wont power on
you should get the systemboard replaced and regarding the power button its a less expensive but replacing the systemboard needs to be replaced as two power supply cannot be bad.
Jun 09, 2008 | Gateway GT4022 PC Desktop
No power except fan
It's your CPU. It sounds like you didn't apply the thermal liquid between your CPU and fan.
Mar 29, 2008 | Gateway GT4022 PC Desktop
Computer will not turn on ?
Hi, first thing to check is the wall power outlet, plug your lead into a diferent outlet or plug a light into the same outlet to test the power. If this doe's not fix the problem then remove the left hand side cover from your case, turn the power on and see if you have a red or green led light on the motherboard. If you dont see this then your power supply has failed. If you see a light on your mother board and feel able then trace the wires from your on/off switch and unplug them and bridge them with a screwdriver to see if this starts your computer. if so then the front switch is dead. You would then need to replace the switch. Good luck, mistyman
Aug 29, 2007 | Gateway GT4022 PC Desktop
Gateway GT4022 PC Desktop Logo
176 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
