Question about Zanussi WJS1265W Front Load Washer/Dryer
Lost instructions on how to use hec 1050w
I simply can't work it out..it constantly takes in cold water..it does'nt heat up & it does'nt like spinning & it takes forever to even get a simple wash done..it just does'nt seem to respond to program selections..What am I doing wrong or is just an over rated over priced rust bucket...can anyone help...thanx julian.
  • nharkness May 11, 2010
    imhaving the same problen......have you found out yet how to work a simple wash? as i havnt....can you help me pls naomi
SOURCE: Lost washing instructions for HEC
turn small left dial to 40.
Then turn right dial to the wash you desire:
(cotton)1. intense 2.prewash 3.normal 4.middle 5.delicate
(synthetic)6.normal 7.middle 8.delicate
(wool)9. normal 10. delicate
(silk) 11.normal 12.delicate
13 quick 14 rinse 15 spin 0 end
hope this helps
Posted on Jan 05, 2010
SOURCE: lost manual for HEC 1050w washing machine. Not sure which compartment i use for powder conditioner. Think i've been using wrong one!
turn the dial to zero, turn it off. it does this at the end ofa cycle and until you set it to zero it will flash when you turn it on.
Posted on Jan 21, 2010
  • 58 Answers
SOURCE: where can i get manual for HEC washing machine
http://www.haier.com/products/product.asp?proID=10580
Posted on Mar 09, 2010
heatman101
  • 43501 Answers
SOURCE: not allowing water in, and
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Posted on Aug 17, 2010
rickyrt441
  • 4399 Answers
SOURCE: My HEC 1050w washing machine
Thanks for choosing FixYa and welcome to the site. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Posted on May 07, 2011
Is it possible to print off the instruction manual for the HEC 1050W washing machine
Hi Geoffrey,
  1. Here is how to do it. Click on this link and download & save it to your PC.
  2. Then open it, you can choose which page you want to print.
Best of Luck
JP
Haier HEC1050S User Manual
Jun 25, 2015 | Washing Machines
Hec 1050w
oh hec its a hec
have you cleaned the filter
Feb 03, 2014 | Washing Machines
Hec 1050w
First thing would be to check the motor electrical connections, and test the motor. If all that tests good I would check all the wiring. There are many parts that contribute to the operation of the motor and I would recommend a qualified repairman.
Dec 03, 2017 | Washing Machines
My heater costantly blows cold
if your heater constantly blows cold then there is a problem with water circulation I:e the heater has a small radiator like your engine has a large radiator the small heater radiator is called a matrix instead of just cooling the water passing through it like the radiator for your engine it is designed to give heat via a fan that blows through it so when it fills with hot water from the engine bay the blower fan blows through it thus giving heat inside the car if it is blowing cold then there is no water getting to it or the water is low in engine bay or there is a blockage even possibly a leak or quite simply the switch that controls the flaps to give you hot or cold air is stuck in the cold position with out more info and me asking more questions this is the basic idea of how it works
hope this helps
Oct 22, 2013 | Cars & Trucks
Dont seem to get cold air, what is the best symbol to use? There is sun, snowflake, rain drop and few others either way it takes forever to get the house cold and sometimes it just simply just does not...
To get cold air set temp 23 degree and mode "cool".
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Dec 30, 2010 | Heating & Cooling
Not allowing water in, and not rinsing.....it is hec 1050w
heatman101
Aug 17, 2010 | Washing Machines
Zanussi WJS1265W Front Load Washer/Dryer Logo
523 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
